glass roof blinds
08.05.2020 14:51 # 1
serkan2457
hello what is sunrof's effect on fuel I wonder if i open the windows as well it burned a bit too much 2004 xt
thanks
let's 2010-07-25 16:57:57
08.05.2020 14:51 # 2
GokhaN
[QUOTE = serkan2457] hello what is the effect of sunrof on fuel, I open the windows as if it burned a bit too much 2004 xt hdı
thanks
It does not have a lot of effect. Always keep an eye on the fuel gauge. You get out of the car Göz Kırpma
08.05.2020 14:51 # 3
serkan2457
I understand, I changed the air filter, the pollen filter oil, the new oil filter, so it may have burned too much.
08.05.2020 14:51 # 4
serkan2457
does not anyone know
08.05.2020 14:51 # 5
ibrahim YILDIZAK
The diesel car I know is not used very smoothly.
08.05.2020 14:51 # 6
serkan2457
I understood it was the first time I used a diesel vehicle.
08.05.2020 14:51 # 7
vbmaster
Throwing down 3000 gear ..
08.05.2020 14:51 # 8
serkan2457
I changed gears in 3000 fuel consumption, more was more than 2000 cycles
08.05.2020 14:51 # 9
You've heard of legend hunters on the Discovery Channel.
They tried the same myth
There is an event that turns into a world legend rather than an urban legend, as if the windows are all open or closed, the air conditioner light burns less.
There is the idea that rubbing with the windows open and the air that fills into the car is believed to slow down, because people believed to slow down, people tried it, the guys completely empty a jeep's gas tank. they put the same amount of gasoline in the two cars and looked at how many kilometers they would travel until the gas runs out.
08.05.2020 14:51 # 10
okankrgz
thanks
If you think so thin, sell the car
08.05.2020 14:51 # 11
Carmania
This is how the glass is open, it burns and I am amazed to see the conversations :) Since the air pressure forces the vehicle to slow down, it burns the gas too much, from the front to the back bumper, it makes a hole like right and left, and it does not hold the air too much car and performance. we win: D ha maybe fuel drops Embarrassed
08.05.2020 14:51 # 12
karayel1984
Upgrade 3000 and decrease from 2000. I read in the forum and on the site of peugeot
08.05.2020 14:51 # 13
okankrgz
[QUOTE = Carmania]
AlkışEmbarrassed
08.05.2020 14:51 # 14
you are very real Kahkaha
08.05.2020 14:51 # 15
deniz_206
friends use my tactic to burn less gasoline then see the high gear low rpm result: =)
08.05.2020 14:51 # 16
H-a-d-i
[QUOTE = deniz_206] friends apply my tactic to burn less gasoline then see the high gear low rpm result: =) [/ QUOTE]
yes, it is useful to use it as it is called "dead hand".
08.05.2020 14:51 # 17
deniz_206
[QUOTE = Come on] [QUOTE = deniz_206] friends apply my tack to burn less gasoline then see the result of high gear low rpm then: =) [/ QUOTE]
yes, it is useful to use it as it is called "dead era". [/ QUOTE]
Come on, dad, after the last gasoline hikes, I started this method, and even I wasted in most places. EmbarrassedEmbarrassedEmbarrassed
08.05.2020 14:51 # 18
serkan24577
Of course, it took the diesel to be calculated.
08.05.2020 14:51 # 19
Selim Engin EREN
best cycle dead cycle Kahkaha
08.05.2020 14:51 # 20
34BC
On diesel vehicles, the dead cycle obstructs the EGR valve. deaf the vehicle.
Page : / 2
