glass removal for stop dimming ??
08.05.2020 18:42 # 1
princealtair
Hello friends, my sonar has 3 stop lights as you can see in the picture, I do not like the chrome, I want to paint it in matte black to match the angels, but how do we remove the glass of this?
08.05.2020 18:42 # 2
HUN
With a blow dryer, you will heat a beautiful silicon and you will slowly pull the glass
08.05.2020 18:42 # 3
princealtair
normal blow dryer from household
08.05.2020 18:42 # 4
samet206
I recommend this type of stop to the foil on the outside, however, it is important to get rid of the silicones that you want to disassemble first, then to re-seal them with a beautifully solid silicon.
08.05.2020 18:42 # 5
HUN
yes, you will control it regularly by heating it in the normal blow dryer or oven, but the blow dryer is easier
08.05.2020 18:42 # 6
reality59
You can also make it easier and recyclable with my black transparent film.
reality59 2014-07-17 02:04:51
08.05.2020 18:42 # 7
princealtair
I understand, let's try the blow dry, we can make foil if we can not disassemble it.
08.05.2020 18:42 # 8
reality59
I think there is no possibility to break the glass when you do it with direct foil.
08.05.2020 18:42 # 9
princealtair
[QUOTE = reality59] I think there is a possibility of breaking the glass while doing it with direct foil removal [/ QUOTE]
I think you're right because plastic can break this
08.05.2020 18:42 # 10
fætih
glass will not break. open the blow dryer on the bottom at the highest temperature starting from the corners ...
08.05.2020 18:42 # 11
aokaymaz
I think the probability of breaking is high because I guess the stops are not like headlights, they are glued with a press instead of silicone (of course, I am not sure if the stops are not in my hand, but I can not say anything but when I think of the stops that I have received before, only the old mercedes born hawk stops etc. the ones other than silicone are sticking presses) So You're likely to break it.
With the hair dryer at home, the work is very difficult, at least until it provides the necessary heat, the blow dryer protects itself and stops.
Of course, the final decision is yours.
