Glass opening / closing hk.
08.05.2020 17:01 # 1
datelk
Guys, I'm having trouble opening / closing the left windshield and left rear window.
When I press it to download it is normal. When I pull it to close it, it keeps getting 2-3cm up. I have to pull the glass over and over again in order to close it. I wonder why? Thank you.
08.05.2020 17:01 # 2
ahmetismet
I think it is contactless. If it does, it does not cause any trouble to open the rim and clean it with contact spray. I did it now, I use it without problems.
08.05.2020 17:01 # 3
istanbullu_3886
There was a setting like opening the contact halfway and holding the glass knob up but I can't remember I think it helps if there are friends who know exactly
08.05.2020 17:01 # 4
dukenukem82
The impact sensor may be defective or stuck somewhere. Auto lockers or electricians solve your job.
08.05.2020 17:01 # 5
boorock
After closing the window completely, force it to close a few times. It may have happened because you probably removed the pole etc.
08.05.2020 17:01 # 6
fatihgg
I was trying to remove it, I don't know how it came to print on the right glass in the night. 3-4cm shield was closed from the alarm but it was closing in a single time.
