glass lifting module
08.05.2020 16:05 # 1
muhammed43040
slm friends I have a malfunction in the glass lifting module of my 307 vehicle, I think I removed the battery terminals and re-inserted the system that closes all the windows when I press the key for a long time.
08.05.2020 16:05 # 2
tilbe307
it was because the polar heads were dismounted. it hadn't worked in my car. I think you need to connect it to the computer and re-introduce it.
08.05.2020 16:05 # 3
muhammed43040
tilbe307 thank you for your interest solved the problem, I had to reset it, I reset it
08.05.2020 16:05 # 4
hasan
[QUOTE = muhammed43040] tilbe307 thanks for your interest solved the problem I had to reset it was reset I reset it [/ QUOTE] reset reset ??? Check out the program
08.05.2020 16:05 # 5
droprain72
My friend, how did you do the reset work? My back windows are closing, but the windshields are not closing.
08.05.2020 16:05 # 6
If the reason why the windows are not closed is the insertion of the battery terminals, we can probably say that the 3 minute rule was not applied while removing the polarity.
Resetting the windows can be done as follows. I hope it works:
Place the key in the contact.
Open the windows fully (lower down).
Close the windows completely.
Press and hold the button on the key for a few seconds.
Remove the key from the contact.
Reinsert the key into the contact.
08.05.2020 16:05 # 7
loiz
Does this glass removal work at 206 XTs?
08.05.2020 16:05 # 8
loiz
I tried it, the glasses are not even there :)
08.05.2020 16:05 # 9
ahmisk
Have you checked your insurance?
08.05.2020 16:05 # 10
VEDATDINC
Open the contact by holding the buttons in the window opening position, wait for 3 seconds, and hold it for 3 seconds by bringing the window to the closing position.
08.05.2020 16:05 # 11
___KxL___
This feature is also available in 206 XT friends, I was wondering now
