Glass lift buttons help ???
08.05.2020 16:08 # 1
nteker
There are 2 problems with my friends tool glass lift buttons:
1. si is sometimes a problem in lifting and lowering the nail on the driver's side. It can be removed by the driver when it is downloaded from the side.
Friends can they be repaired?
08.05.2020 16:08 # 2
istanbullu_3886
[QUOTE = nteker] My friends tool has 2 problems with the glass lift buttons:
1. si is sometimes a problem in removing and lowering the nail on the chauffeur side. It can be removed by the driver when it is downloaded from the side. they made the plastics were broken, but they paused and lifted it, I replaced it with a new one
08.05.2020 16:08 # 3
nteker
I wonder how many lira is the new one
08.05.2020 16:08 # 4
If your hand is somewhat susceptible to these tasks, insert it and try to detect the problem. Since it is a place that can be exposed to rainwater, the water may leak into the contents and oxidation may occur in the contacts. You can insert and plug in 5 minutes. Reviews
08.05.2020 16:08 # 5
nteker
Thank you I will try to try
08.05.2020 16:08 # 6
metin
For the price, I recommend you to contact the falcon peugeot murat brother.
08.05.2020 16:08 # 7
Bavik
go to an electrician, view, you didn't have a friend, I do not think there will be anything too expensive, buy something new, I have had the same problem once in a while, the electrician handled it & nbsp;
