glass gap remains
08.05.2020 16:16 # 1
Muhammet
I would love to say everyone enjoyable forums, but I can't say we had a pleasant day after the news of martyrs. May Allah give you a thousand troubles of terrorists ...
< div>
I have a 307 cc vehicle, it closes on the windows automatically when closing the top, and the rear right window, the right front window does not fit properly and the gap remains, I fix it with my hand. If anyone knows where I can do this, I would be very glad if he shares it with me.
08.05.2020 16:16 # 2
metin
Lift the contact halfway open the glass with your hand to the end, after removing it thoroughly, press the button for 5-10 seconds and introduce it as if it is still lifting the glass. It will likely be improved.
& nbsp;
when it automatically closes when it sees that level as the end of the glass it is stopping there glass.
08.05.2020 16:16 # 3
Muhammet
Instead of going straight out rather than level finishing, it is skewed somewhere rather than the top, but it remains separate from the side, but I thank you very much for your suggestion, I will try it
08.05.2020 16:16 # 4
metin
then one of the rails on the edges is loose, after it reaches a certain level, it is derailing
08.05.2020 16:16 # 5
Muhammet
Yes, it is likely that it is separated from the side, not from above, because even with my hand, the wind is getting in. The rain does not enter, but it makes a lot of noise, and the car is freezing in the morning. Does it have a setting? n o ne ">
