Glass control panel malfunction
08.05.2020 15:13 # 1
sace
Hi friends. My vehicle 2002 307XR. There was a minor malfunction in the glass control panel recently, and holding the glass automat on the driver's side did not open or close until the end. Other windows operate smoothly from the same panel, only the left windshield moves by pressing the key, and remains as it is when you release it. I did not force too much, but now the same key is quite loose and I can only pull the window down, lifting is only from the remote control, which happens when the key is not in contact. My question is, can you just change that key to work and relax without changing that panel completely and can it be obtained from the barriers?
08.05.2020 15:13 # 2
Probably, the support points at the edges of the key are broken. When mine was broken, I had a Japanese grove attached and replaced it with one of the rear windows. The backs are not used as often as they are. However, I think you can find this key as one. Koliva 2011-04-05 22:23:09
08.05.2020 15:13 # 3
insomnia
In these cases, I use a term like this to the right electrician who is stuck with money.
08.05.2020 15:13 # 4
sace
:) where is the solution there. Thanks...
08.05.2020 15:13 # 5
iibrahimm
Look at a people who are well-suited, there was a problem with me.
08.05.2020 15:13 # 6
bestfear
I had a problem on both sides. Since the nails were broken, the key was not doing exactly the task ... With a 15-20 minute process, I made both of them more solid than before ... How? I removed the panel, instead of the broken nails, I cut the thin nail (glass nail) in the same size. I heated it and pierced it through the nails, I inserted it between the key ... it was much stronger than before ... I wish I used the nail while doing peugeot :))
08.05.2020 15:13 # 7
sace
[QUOTE = bestfear] I had a problem on both sides. Since the nails were broken, the key was not doing exactly the task ... With a 15-20 minute process, I made both of them more solid than before ... How? I removed the panel, instead of the broken nails, I cut the thin nail (glass nail) in the same size. I heated it and pierced it through the nails, I inserted it between the key ... it was much stronger than before ... I wish it used the nail while doing peugeot:)) [/ QUOTE]
I'm looking for some adventure. I hope it is free to try, I will not spoil it well :) At least I will take it out and take a look. :)
08.05.2020 15:13 # 8
iibrahimm
Do not say my master did not say that the parts of this crap are too expensive, if your hand is inclined, take it off or give it 3 5 kurus who knows
08.05.2020 15:13 # 9
bestfear
my brother's carpenter's workshop became my car's workshop ...
If your hand is somewhat inclined, if there is a need, etc., why not ... Just pay attention to what and how to remove when disassembling ...
08.05.2020 15:13 # 10
Nice idea is actually. It is not necessary to play while warming the lone glass curve or a record is gone. Your hand should not vibrate. If it breaks again, keep in mind this method Göz Kırpma
08.05.2020 15:13 # 11
bestfear
[QUOTE = iibrahimm] Do not say my master did not say the parts of this meret is too expensive if your hand is prone, take it out or give it 3 5 cents to know [/ QUOTE]
The parts are really expensive, especially the prices of the parts that are thought to not hold much money hurts ...
08.05.2020 15:13 # 12
sace
If the broken orca is the same as the glasses, it can be replaced. it is used less after all but i dont know my warning
08.05.2020 15:13 # 13
bestfear
[QUOTE = koliva] Nice idea is actually. It is not necessary to play while warming the lone glass curve or a record is gone. Your hand should not vibrate. If it breaks again, keep in mind this method Göz Kırpma [/ QUOTE]
On the one hand, it is necessary to fix it alone, to spend it on one hand .... Brother, I kept it. Sırıtma
