Glass closing problem with remote control
08.05.2020 16:40 # 1
kiracoglu
& nbsp; Friends noticed that when I locked the car with the window open, I keep pressing the door knocks but the windows do not close. I tried quite a bit, but it does not happen .. Dha first there was no problem. I have changed the battery, I say it may be something about it, I do not remember exactly, but it was as if it was working after the battery changed ..
Is there a method like activating the
control, when the contact is on, etc. Is there a method smileys / smiley21.gif "border =" 0 "alt =" Thumbs Down "title =" Thumbs Down "/> & nbsp; & nbsp ;?
08.05.2020 16:40 # 2
isodogu
Some features may be canceled after battery replacement. Open the car's ignition and lower the driver's window completely, and after the window has completely lowered, do not leave the button for 10 seconds.
08.05.2020 16:40 # 3
selkentli
As the eastern says, when the battery is removed and installed, it is automatically disabled. After the battery is connected, close the windows completely, then close and pull the ignition, then hold the button for a few seconds to close the windows, then check it will become active. ..
08.05.2020 16:40 # 4
metin
As the eastern [QUOTE = selkentli] said, the battery is automatically disabled when the battery is removed and installed. After the battery is connected, close the windows completely, then close and pull the ignition, then hold the button for a few seconds to close the windows, then check it will become active. .. [/ QUOTE]
no the key should not be removed and the contact should not close until the synchronization process is complete.
contact When the glass is half open, the glass will be lowered to the end and the download button will be pressed for 5 seconds after the window is closed. / div>
08.05.2020 16:40 # 5
toga406
Do you have this feature in sv models in 2003 model 406 automatic? Is there anyone who knows that I do not turn off?
08.05.2020 16:40 # 6
ByHack
press and hold the control button of the feature you want to activate in peugeot, it becomes active "T & nbsp; by the way, I do not know how on other models but if you disassemble the battery terminals 3 minutes after stopping the car in 307s, no feature is disabled, ECU standby goes into mode. windows, headlight sensor etc. all remain active. hard to experience :) ByHack 2012-05-03 00:03:20
08.05.2020 16:40 # 7
kiracoglu
Thank you guys, I will try what you say tomorrow .. the problem is solved in my guess .. thank you, exist & nbsp; "Smile"
08.05.2020 16:40 # 8
mavituna
is the problem resolved & nbsp; how did you do it?
08.05.2020 16:40 # 9
gngburak
I did it as you said, I kept it pressed for 5 seconds, it sounded like a click on the door, but nothing changed happened again.
Actually, I have to ask if there is such a feature in my vehicle
2005mod. 206 x-line
08.05.2020 16:40 # 10
metin
I don't know in the 206's, but there is an automatic window closing in the 307's. >
First we open the contact halfway, the battery lamp will be on. Then, we will lower the window to the end and hold the button down for 5 seconds, as if we would like to lower the glass even though the window was open. Then we will wait for 5 seconds by pulling the button up, closing the window to the end, and pulling the button up as if it is open on the same closed glass, and the calibration process will be completed. & Nbsp;
This feature was passive when I disassembled it and I was fixing it that way. When I long pressed the remote control, 4 windows + sunroof closed automatically.
08.05.2020 16:40 # 11
206206
206 & nbsp; s the & nbsp; I guess not & nbsp; & nbsp; window closure with remote
08.05.2020 16:40 # 12
pt206
[QUOTE = text] I don't know in the 206s, but there is an automatic window closing in the 307s. & Nbsp;
As you know, the window closes when you push the button up, the glass opens when you press down. & Nbsp;
usunda/QUOTE]<
my car 2005 model 206 XT
08.05.2020 16:40 # 13
206206
Control the & nbsp; door opening button & nbsp; Does & nbsp; & nbsp; down & nbsp; for the window closing and opening button to be held
08.05.2020 16:40 # 14
mavituna
[QUOTE = text] I don't know in the 206s, but there is an automatic glass closing in the 307s.
First, we turn the ignition on halfway, the battery lamp will be on. Then, we will lower the window to the end and hold the button down for 5 seconds, as if we would like to lower the glass even though the window was open. Then we will wait for 5 seconds by pulling the button up, closing the window to the end, and pulling the button up as if it is open on the same closed glass, and the calibration process will be completed. & Nbsp;
This feature was passive when I disassembled it and I was fixing it that way. When I long pressed the remote control, 4 windows + sunroof was closing automatically.
You explained it very well, but I have not tried it. I have a 2004 model 307 XT automatic transmission. I have not tried several times. Is it necessary to long press the key when locking the door? I haven't tried this.
08.05.2020 16:40 # 15
metin
When we lock the door, we press long press, that is, lock the door, and we continue to press the button even if the doors are locked. After the doors are locked, there will be a click, and the windows will start to close. happening too.
08.05.2020 16:40 # 16
vegubaah
There is a 2013 model 2008 activ Peugeot. rear left window & nbsp; good memory & nbsp; when I try again a little later & nbsp; a few inches coming down and storing okay. & nbsp; & nbsp; & nbsp; I turn it off with the control a little later, the rear left window remains, others close. there is a like and no like. Nobody knows in the industry, 4-way control will change. Is there any other way? Can you help Veli GÜNGÖR from Isparta?
08.05.2020 16:40 # 17
erdiano
Hello, is there any possibility to open and close the windows from this remote control in my 2006 model 307 1.4 comfort model car? I was never aware of such a feature, and I was excited when I read it here. Experience at the first opportunity, if any. But is it simple to add this feature? & nbsp; erdiano 2016-12-25 18:06:51
08.05.2020 16:40 # 18
ggitaristt
[QUOTE = erdiano] Hello, I wonder if it is available on my 2006 model 307 1.4 comfort model car to open and close the windows from this remote? I was never aware of such a feature, and I was excited when I read it here. Experience at the first opportunity, if any. But is it simple to add this feature? & nbsp; [/ QUOTE]
If 4 windows are automatic then there is probably.
Insert the key in the door and turn it to the locking direction, wait for the back, the windows start to lift in 2 seconds. or hold the lock button on the remote for 2 seconds when the doors are closed but not locked. try ..
edit: We tried in 2003 xt even the sunroof was closed
ggitaristt 2016-12-25 20:35:38 < / edited>
08.05.2020 16:40 # 19
erdiano
[QUOTE = ggitaristt] [QUOTE = erdiano] Hello, is there any possibility to open and close the windows from this remote in my 2006 model 307 1.4 comfort model car? I was never aware of such a feature, and I was excited when I read it here. Experience at the first opportunity, if any. But is it simple to add this feature? & nbsp; [/ QUOTE]
Thank you very much. But first I need to change the car's fuse box :) The car is not working right now. & Nbsp;
08.05.2020 16:40 # 20
oktay_conan
Hello friends. & Nbsp;
I just joined you 1 week ago I bought a 2004 model 307 1.4 hdi xr vehicle. I tried this glass removal event but it didn't. The vehicle does not have its original control, so there is a switch with a switch, which can be switched later. Isn't it because of this, can you help?
Page : / 2
