GLASS AUTOMATIC
08.05.2020 18:45 # 1
iaksoy06
HELLO FRIENDS,
2002 MODEL I HAVE A 307 1.6 XT, BATTERY IN THE PAST LASTING, I CHANGED A PROBLEM IN THE GLASS AUTOMATIC AFTER CHANGING. NORMALLY, TO KEEP THE CAR FROM THE CONTROL, THE BUTTON IS CLOSED WHEN THE WINDOW IS ON WHEN THE WINDOW IS OPEN, THE BATTERY CLOSES THE REAR ONLY AFTER THE REPLACEMENT. DOES ANYONE HAVE INFORMATION WHY CAN IT BE?
08.05.2020 18:45 # 2
samet2461
teacher, open the contact, open the front windows, lower the contact, close the contact, then open the contact again, raise the front two window buttons, hold it for 10 seconds, close the windows, then release the buttons, close the contact. then try to download and try in four mosques Smile samet2461 2014-08-08 11:51:24
08.05.2020 18:45 # 3
iaksoy06
Thank you, my teacher solved the problem, it works perfectly well.
08.05.2020 18:45 # 4
samet2461
[QUOTE = iaksoy06] Thank you, my teacher solved the problem, it works fine. [/ QUOTE]
Smile
