gives an audible tone after starting |
| 08.05.2020 15:03 | # 1 |
| 08.05.2020 15:03 | # 2 |
sercinho |
slm my brother, look at his sockets, I don't have a problem, connect to a pc, look at my pc, he can be in connection.
| 08.05.2020 15:03 | # 3 |
volkan_uysal |
Hi there is no morning! [QUOTE = orko] warning sound when I start the car and the airbag lamps sometimes go out sometimes stay on constantly ... the car 2005 model 206, gasoline, automatic problem, I would be glad if you give information about what could be caused [/ QUOTE] |
| 08.05.2020 15:03 | # 4 |
Yusuf Tekoglu |
I have the same problem with me when I go on the road, I go a little bit, I go out, I don't have any work with an airbag attached to my head :)
| 08.05.2020 15:03 | # 5 |
gozem |
my 307 was doing airbag and abs lamp. As a result, the airbage diode was installed, the speed sensors for abs were removed and cleaned. I paid 40 lira each. |
| 08.05.2020 15:03 | # 6 |
When you pray, don't let them work with you :( I have the same problem with me when I go on the road, I go a little bit, I go out, I don't have any work with an airbag attached to my head :)
| 08.05.2020 15:03 | # 7 |
I have the same problem, sometimes when going on the road, the airbag lamp lights up with the warning sound and sometimes goes out. |
| 08.05.2020 15:03 | # 8 |
deniz_206 |
I have the same problem, I connected the device to the vehicle, the oxygen sensor malfunctioned. |
| 08.05.2020 15:03 | # 9 |
[QUOTE = orko] warning sound when I start the car and the airbag lamps sometimes go out sometimes stay on constantly ... the car 2005 model 206, gasoline, automatic problem, I would be glad if you give information about what could be caused [/ QUOTE] Replaces the battery.
