gırrr gırrrr nebuu ya ??
08.05.2020 15:28 # 1
muurrat
friends have a 1.6-tube 2002 206m when the car is running and the lights stop, I see the sound of the clutch, but the coil passed by the day it was, but it still feels so bad
08.05.2020 15:28 # 2
ose
pull your idle foot off the clutch?
08.05.2020 15:28 # 3
106_arts
Is it just standing still
otherwise I will come to the clutch pressure_?
08.05.2020 15:28 # 4
106_arts
by the way your vehicle is not 1.6 16v 110hp 90hp
I also saw the vehicle from the owner com
08.05.2020 15:28 # 5
muurrat
[QUOTE = 106_arts] by the way your vehicle is not 1.6 16v 110hp 90hp
90 I guess full blmyrum or normar idle sound is sound car is running
08.05.2020 15:28 # 6
eneslan
What does Arba mean? Is it my car or another phrase I don't know?
08.05.2020 15:28 # 7
ose
my friend, try this, when the idle clutch stops sounding, if it does, the clutch ball has failed.
08.05.2020 15:28 # 8
muurrat
arba car demk yes no no, I don't try to cut it but it doesn't do it all the time
08.05.2020 15:28 # 9
I had the same sound in me 1 month ago .. when I stopped at the lights ... when I run it .. it was cut when the drain was pressed, but mine .. anyway, we got the ball from the drain ball..but it was not .. Otherwise, it would cause more expenses ... so I think you can go to a master right away .. you can also have a ball of drainage .. there may be a ball in the gear .. it will give the best answer to the master.
08.05.2020 15:28 # 10
muurrat
[QUOTE = by_ersin] 1 month ago, the same sound was on me ... when I stopped at the lights ... when I run it .. it was cut when the drain was pressed, but .. anyway, we got the ballast out of the drain ball..but it wasn't a ball .. I ran it to the master, we changed it ... it would cause more expense ... so I think you can go to a master right away .. it can be from the ball of drainage .. there is a ball in the gear, it may be in it .. the best answer will be the master. [/ QUOTE]
thank you for your comment let's see a demonstration today
08.05.2020 15:28 # 11
toprakk
clutch balls need to be replaced. but he also needs to get the transmission down. For example, your voice is making a lot in anarya, it goes in that sound.
08.05.2020 15:28 # 12
ose
man, I have this problem. What did the workmanship cost and where exactly did it cost?
08.05.2020 15:28 # 13
muurrat
yesterday i showed the master to the master, a hose that the tube was connected to was idle, it strummed ohh no problem, allhatan
08.05.2020 15:28 # 14
[QUOTE = muurrat] I showed the car master yesterday, I was stuck with a hose that the tube was connected, it was stuck ohh no problem, allhatan ya [/ QUOTE]
god emi you Sırıtma thank goodness you were ripped Sırıtma saint of hotum while thinking of gearbox or something Gülme
08.05.2020 15:28 # 15
muurrat
Do not ask me, do not ask me if you think you are here or something.
08.05.2020 15:28 # 16
[QUOTE]
But with your recipe, those troubles would be gearbox balls vss ... always ... I have never heard of those who said they were already in the solution. Sırıtma But I'm glad your work is not broken up. Thank God ..
