getting out of bsi for foot lighting?
08.05.2020 17:06 # 1
Alicilik
Hello friends,
There is an event that we call foot lighting in luxury vehicles. Many friends in the forum did this. I also added the lighting of the vehicle and equipped it in the daylight yellow color called warm white. I am thinking of doing the rifles and door edges.
I thought the ceiling lamp about where I would take the current, and it is not unreasonable to put a button. So I'm thinking of finding the exit from BSI and ending less hassle until I pull the cable from the ceiling. & Nbsp; I am waiting for the help of sensitive friends who are knowledgeable about this. Reviews
08.05.2020 17:06 # 2
spearo
If my buyer is patient, I will answer the problem, I get into the torpedo lamp business, I will dismantle the torpedo. and I think of similar footlight under the front door. Where there is electricity voltage bsi what it is when I dissolve my messages. I am lost in the small sedre documents. >
08.05.2020 17:06 # 3
blinddark
I think BSI or something, I did 307 for the front and back, you can not see any cable for the back of the back floor, it was a bit tricky to get the cable down from the ceiling, but it did not even take 10 minutes to lower the cable from the ceiling.
08.05.2020 17:06 # 4
ahmetismet
Don't bother with BSI or something, pull the cable from the cigarette lighter socket under the dashboard, connect the strip leds. I have been using it for 2-3 months, no problem. My only advice is to install a light-tuned system because it doesn't look good when it is too bright. Dim light is more beautiful ...
08.05.2020 17:06 # 5
Alicilik
There is a lot of space after I want to buy electricity.
My aim is to adapt to the opening of the door. I also put an arduino until I add a control unit: D
I want to get it from BSi because the cables that were pulled out later will cause trouble 5-10 years later, neither me nor anyone else.
Also, if I learn the BSi outputs in detail, I will make a daytime running light to the output of the tape. When I open the doors in my car, the tape starts working and the tape turns off 50 seconds after locking.
08.05.2020 17:06 # 6
blinddark
[QUOTE = Buying] There is a lot of space after trying to get electricity.
Also, if I learn the BSi outputs in detail, I will make a daytime running light to the output of the tape. When I open the doors in my car, the tape starts to work and 50 seconds after locking it. The tape turns off. I got angry too and put the headlights on the trunk "Big & nbsp; My first goal now is that the fog of the vehicle is burning after the headlight is on, or it was not possible to connect it to the fire after the parks or to burn it directly with the help of the button and the button.
08.05.2020 17:06 # 7
spearo
Also, if I learn the BSi outputs in detail, I will make a daytime running light to the output of the tape. When I open the doors in my car, the tape starts working and the tape closes after 50 seconds after locking. Ali ? Reviews
08.05.2020 17:06 # 8
Alicilik
[QUOTE = spearo]
Where is the electric power of the tape, the tape works when the door opens.
What is the daytime running light to the output of the tape?
From the tape socket of the vehicle, the brother does not buy from another place.
Now I have a daytime led project. There are 3w round water resistant leds. I will take 6 of them and make them on the grill. I say that I will get the electricity from the tape instead of operating it with a button. Because it would be great if I could attach it to the tape with electricity (not from the battery, but from BSI). Because when I locked the car, the tape works and turns off after 50s. Again, as soon as you open the car, it opens on tape. If I connect this way, the possibility of forgetting it is cleared.
[TUBE] K_fAJd_Qadk [/ TUBE]
Alicilik 2012-11-01 16:04:05
08.05.2020 17:06 # 9
halilefe
Guys, I just bought the vehicle, but it was not on the original tape. There is a 50 TL buckled tape but my control arm is not working. Problem is the tape or my control arm is faulty. I'm waiting for your help.
08.05.2020 17:06 # 10
fTh206
[QUOTE = halilefe] Guys, I just bought the car but it was not on the original tape. There is a 50 TL buckled tape but my control arm is not working. the arm is canceled so it is disabled so you need to wear your original tape for the arm to work
08.05.2020 17:06 # 11
tellotello
[QUOTE = halilefe] Guys, I just bought the car but it was not on the original tape. There is a 50 TL buckled tape but my control arm is not working. Problem is the tape or my control arm is faulty. I'm waiting for your help. & Nbsp; [/ QUOTE]
< / div>
Whatever model your vehicle says, it can be more helpful. It is very normal that the control lever does not work. I guess the person who changed it just removed the tape and installed a new tape. If the tape is available from the output they call W / R, intermediate apparatus is sold. div>
08.05.2020 17:06 # 12
Alicilik
[QUOTE = tellotello]
Whatever model your vehicle says, it can be more helpful. It is very normal that the control lever does not work. I guess the person who changed it just removed the tape and installed a new tape. If the tape is available from the output they call W / R, intermediate apparatus is sold, you can buy and install it on ebay and then your joystick will be activated. & Nbsp;
Example apparatus link:
http://www.ebay.co.uk/itm/ Peugeot-206-307-406-steering-Stalker-Control-Adapter-CTSPG006-Pioneer-Stereo- / 270 877 908 574? uk_ın_car_technology ptr = & amp; hash = item3f1194de5
Reviews [/ QUOTE]
Mahmut teacher poured again "Big health to your hands
Less I will complete this led post and then I will share all the information in a header for this tape. I would even ask for a fixed title if possible "LOL" But after a while the midterms started
08.05.2020 17:06 # 13
tellotello
[QUOTE = Buyer] [QUOTE = tellotello]
Reviews [/ QUOTE]
Less I will complete this led post and then I will share all the information in a header for this tape. I would even ask for a fixed title if possible "LOL" But midterms started a little later
I grabbed something from you, I keep writing down everywhere I'm going to go & nbsp; "LOL". When we change my tape, we shoot a video and put it on the page, I have salt in the soup too & nbsp; "Big.
08.05.2020 17:06 # 14
Alicilik
I grabbed something from you everywhere I keep writing about it & nbsp; "LOL". When we change my tape, we shoot a video and put it on the page, I have salt in the soup too & nbsp; "Big.
[ / QUOTE]
This is how I learned it "Big We will do nice things in the pieces. Reviews
08.05.2020 17:06 # 15
tellotello
[QUOTE = Recipient] [QUOTE = tellotello]
I grabbed something from you all over the place, I'm going to go over it & nbsp; "LOL". When we change my tape, we shoot a video and put it on the page, I have salt in the soup too & nbsp; "Big.
[ / QUOTE]
I say I do not dirty this post, but I can't stand it. Steering is for the ready arm, so he's lying at home. smiley1.gif "border =" 0 "alt =" Smile "title =" Smile "/>. The tape is already in my mind, you know, I will pass the order as soon as my job is over, but what I think is the bottom 5 changer I definitely want to get rid of it. It just makes you think of a box to put there. I talked to the private service they said it was too expensive for the original, but it looks like I will get a last resort.
08.05.2020 17:06 # 16
Alicilik
I say I don't get this post dirty, but I can't stand it, Steering is for the ready arm, so he's lying at home, he's pretty sophisticated right now ". The tape is already in my mind, you know, I will pass the order as soon as my job is over, but what I think is the bottom 5 changer I definitely want to get rid of it. It just makes you think of a box to put there. I talked to the private service, they said it was too expensive for the original, but it seems like I will get a last resort. I am waiting for a piece like you, I will share how I got it from hongkong.
Let's say tape-stalk tmm. that frame means a lot of trouble. Mkineci is familiar or not, if we tell him there & nbsp; "LOL"
08.05.2020 17:06 # 17
ibrahim51
really congratulations, whenever I had a sound system, whoever I asked said the arm would be canceled, you succeeded. thanks in advance for your help ..
08.05.2020 17:06 # 18
metegorkem
[QUOTE = spearo] If my receiver is less patient, I will answer the problem, I get into the torpedo lamp business, I will dismantle the torpedo. and I think of similar footlight under the front door. Where there is electricity voltage bsi what it is when I dissolve my messages. I am lost in the small sedre documents. > [/ QUOTE]
when I say left post? Where exactly does this ceiling lamp cable come from? I wonder where is the route?
08.05.2020 17:06 # 19
terziib
I have a jvc r234 tape.
08.05.2020 17:06 # 20
fexzi
The subject has turned a little to the volume control arm, but for foot lighting, I can say, I took the line from the top lamp and placed it in the front and back, there was no problem. you know this kind of work better.
