General, Practical Information - Oil Pressure
Homepage » PEUGEOT MODIFIED PLATFORM » Useful Documents
08.05.2020 14:53 # 1
rifatseker
Low Oil Pressure in Engine;
1- Pressure gauge shows wrong.
2- The hole of the pipe coming to the pressure gauge has narrowed. (Motor).
3- Oil was watered. Or, thinner oil is used than desired.
4- The pressure setting of the oil pressure control valve in the pump is very low.
5- The spring of the pressure control valve is weak.
6- The elements of the oil pump are worn.
7- The element housing and cover of the oil pump are worn.
8- The body or the cover of the oil pump is loose.
9- The gasket of the oil pump is broken, incorrectly installed or too thin.
10- There is air leakage in the pump suction pipe. (The oil level in the crankcase is low).
11- There is air leakage in the oil pump swimmer strainer.
12- Pump suction pipe or strainer is clogged with water, waxing and freezing.
13- There is a leak in the oil discharge pipe.
