General, Practical Information - Air Conditioning
Homepage » PEUGEOT MODIFIED PLATFORM » Useful Documents
08.05.2020 14:53 # 1
rifatseker
If the air conditioner does not cool! If your air conditioner is not cooling, it may be out of gas. The reason for the end of the gas is that there is gas leakage from a crack in the gas pipes. In such cases, it is necessary to detect gas leakage and then complete the gas. The malfunction of the air conditioner radiator and the malfunction of one of the radiator blades also prevents the air conditioner from working properly. Dust, dead insects, leaves accumulated on the radiator also prevents efficiency from the air conditioner. In order to obtain maximum efficiency without cooling, it is necessary to clean such deposits during periodic checks. For the air conditioner to operate regularly, the tension of the compressor drive belt must be checked once a month at the service. In authorized services, it is pressed down to check the tension of the drive belt. If the belt is loose more than usual, the air conditioner will not cool sufficiently. How is the fault detected? If your air conditioner is malfunctioning or not cooling enough, you should definitely go to a workshop or air-conditioning workshop. In the service, the air conditioner malfunction is checked as follows: - The air conditioner gas pipes are checked for gas leaks. If there is a gas leak, its source is detected. - If there is no gas leakage, dirt on the air conditioner radiator and if the radiator is blocked due to corrosion is checked. - If there is no problem with the radiator, the radiator blades are checked. After the gas leakage or other faults are repaired, the air conditioner is completed with a special device. Thus, you will be able to travel cool and cool in sweltering heat with your air-conditioning in your car. What should be considered when operating the air conditioner? - The air conditioner should never be turned on without starting the engine of the car and heating the engine. - The windows should be kept open for a short time so that the heated air can escape quickly. - When the air conditioner works, the heater button should be in the cold position. - After starting the engine, the air conditioner should be operated at low speed, if desired, then at high speed. - When the air conditioner is turned on, care should be taken that the air does not go directly to the driver and passengers. Blows should be given to the base and glass. How is the ideal air conditioning maintenance? - To ensure the air conditioner to work efficiently, it must be checked periodically. - Cooling gas should be checked at least once every 6 months. - When the air conditioner malfunctions, it should not be checked by unauthorized persons and organizations. It should be taken to authorized services. - Whatever gas is used in the air conditioner, the same gas should be used when the gas is renewed. Gases that are incompatible with system elements should not be used. - Even if it is winter, it should run the air conditioner for at least 10 minutes once a month to ensure that the air conditioner equipment works efficiently.
