General Computer Features of Peugeot?
08.05.2020 17:11 # 1
xMEGANx
Can anyone write what they know about the General Features of Peugeot? If you specify how to activate these features, it would be great if I start with 1-2. I list them all below, friends will continue as you add them, so let's collect everything we learned here, let's not forget:) 1- If you turn off your vehicle for a long time after you stop your vehicle, the `` falow me '' feature will follow the headlights for 1 minute. It turns off automatically after 1 minute. 2- In the event of an accident, with Airbags - Retractable Pedals - Retractable Steering Box - Cutting fuel from the warehouse - Leaving the engine under the vehicle. `` Once you have it, it will not be active again. If the wipers are on and you engage reverse gear, the rear wipers clean the window automatically. hangs. (You don't need to do this every time, it remains active until you deactivate it again.) Note: To deactivate it, you need to hold it down again. 5- [_semihk_] After turning off the ignition, you can close and open the windows for 1 minute. If you turn the ignition back on, it will become active. 6- [307 bursa] After stopping your vehicle, if your windows are open, press the lock button for 3 seconds. If you hold down, all your windows including Sunroof are closed automatically. If the model is on the top of the model, all the windows open again when you press and hold the Open button. EK: tellotello> Press and hold the lock button of the remote control for 30 seconds. 7- [serco05] Maintenance KM Reset, If it does not reset the key, the key shape will be displayed on the screen, the contact is mounted on the vehicle to reset the maintenance KM and destroy the key shape, the KM counter on the instrument panel is opened by pressing the reset bar until the last step (no starter) When the screen starts to count down from 10, zero the bar is left, depending on the model of your vehicle, the key mark is set to 15,000 or 20,000. raising and weakening their lights or benefit. When we press the stick, all the lights are gradually reduced and when we press again, all the lights are gradually increased. thus it enters long-distance mode. 9- [Cente] If your car is STOP while your CD player or Radio is on, it will enter Saving mode within 20 minutes (Depending on the battery status, in some cases it may be shorter). By pressing the MODE key from the tape, you can activate the screen, see the details such as clock, but the music does not play. If one of its doors is left open, it shows the door that is open on the screen or your head lamp starts blinking. xMEGANx2013-01-04 01:54:11
08.05.2020 17:11 # 2
Barut
it is very useful for those who do not know some features like me, thanks i am sure this will be very useful & nbsp; "Thumbs
08.05.2020 17:11 # 3
Serkan
Particularly, users of 307 and 308 will remain in the open position if you press the wiper arm down once after removing the contact to remove the wipers in the winter.
08.05.2020 17:11 # 4
Alicilik
[QUOTE = Serco05] Especially if users 307 and 308 press the wiper arm downwards after removing the contact to remove the wipers during the winter, your wipers remain on. [/ QUOTE]
Is it me too, don't you have it in 206?
Let me tell you in a feature. once installed, your rear wiper will run once.
08.05.2020 17:11 # 5
Serkan
There are also 206's Ali, but I wrote specifically for 307 and 308 users because their wipers come under the hood in the normal position and do not lift up, ours normally also.
08.05.2020 17:11 # 6
Alicilik
[QUOTE = Serco05] There are also 206's Ali but I wrote especially for users of 307 and 308 because their wipers come under the hood in the normal position and don't get up, ours normally get up. [/ QUOTE]
Uppsss correct "Ouch" 307 wipers wipe that problem.
08.05.2020 17:11 # 7
EnSoNiQ
would be a useful topic, if the author who knows about our tools knows the unknown aspects
08.05.2020 17:11 # 8
Serkan
[QUOTE = Pickup] [QUOTE = Serco05] Especially if users 307 and 308 press down on the wiper arm once after removing the contact to remove the wipers in winter, your wipers will remain on. [/ QUOTE]
Is it me too, is it not in the 206s?
Let me tell you in a feature. If the wipers are on, when you stop the car, it will not continue when you turn it back. the rear wiper will work once you plug it in.
I get annoyed that the wipers do not continue, every time I start the car, the sensor needs to be reactivated. corrupts. Reviews
08.05.2020 17:11 # 9
Serkan
We press and release the wiper arm downwards, Salih, there is only one wiping method, then it opens the wipers and remains open.
08.05.2020 17:11 # 10
Serkan
Exactly necessary in winter, or & nbsp; wipers stick to glass :)
08.05.2020 17:11 # 11
[QUOTE = xMEGANx] When we parked our car on the roadside for a short time, if we parked on the right side with the shift, we could only burn the left parks of the vehicle, do you know how? [/ QUOTE]
what you say is usually in german vehicles.When the park is open, whatever side you turn the signal lever on, the park stays open.There are definitions in vw and opels, but peugeot has never tried.
08.05.2020 17:11 # 12
Bugra
[QUOTE = Birtan ÇÖTELİ] [QUOTE = xMEGANx] When we parked our vehicle on the roadside for a short time, we could only burn the left parks of the vehicle, do you know how it works? [/ QUOTE]
& nbsp; < / div>
what you call it is generally in german vehicles.When the park is open, whatever side of the signal lever you make, the park remains open. I think this is a bad feature. I mean, if I see a stop light from the back, I can think of a motorcycle. and I can misalign my approach to approaching the vehicle in front. I don't know if I think it's wrong.
08.05.2020 17:11 # 13
Bugra
Bidet has this central clit conversation. I don't know if it's all models but. When the vehicle's doors are closed, when you hold the clit button inside, a dong sound is heard and when the vehicle exceeds 10 km speed, the doors are automatically locked.
08.05.2020 17:11 # 14
hsnsnl
[QUOTE = bugrature] bidet has this central clit chat. I don't know if it's all models but. When the vehicle's doors are closed, pressing the clit button from inside makes a dong sound and automatically locks when the vehicle exceeds 10 km. [/ QUOTE]
& nbsp; I tried the key event you said
sometime but no click, it didn't work: S & nbsp; 2003 model 307
08.05.2020 17:11 # 15
xMEGANx
[QUOTE = hsnsnl] [QUOTE = bugrature] bidet has this central clit chat. I don't know if it's all models but. When the vehicle's doors are closed, pressing the clit button from inside makes a sound like dong and the doors automatically lock when the vehicle passes 10 km. [/ QUOTE]
& nbsp;
I tried the key event you said sometime but no click, it didn't work: S & nbsp; 2003 model 307
I have that feature active. but it is canceled by holding it down. but it is very nice to be like this, when it reaches 10 km speed, it locks immediately :)
08.05.2020 17:11 # 16
harica
Well, there has been a perfect forum. I bought 407 comfort in 2006, it has been 2 weeks, I have experienced the tire pressure indicator myself, and it works very well. I tried reading it from you and it is enough to make the wiper feature go down after a very good event contact is closed. Mine is comfort but after turning off the ignition, when the selector is made, I think this feature had a name for 1 minute to go home with the headlights on. Those who don't know have tried. There are also new things.
08.05.2020 17:11 # 17
_semihk_
it allows to play the windows for a while after the contact is closed .. only when the doors are opened it cancels ... you need to open and close the contact again to play
08.05.2020 17:11 # 18
xMEGANx
I sort all the features at the top, guys. Thank you it was really good for the information. xMEGANx 2012-12-24 00:37:01
08.05.2020 17:11 # 19
Serkan
[QUOTE = Except] Well, it has been a perfect forum. I bought 407 comfort in 2006, it has been 2 weeks, I have experienced the tire pressure indicator myself, and it works very well. I tried reading it from you and it is enough to make the wiper feature go down after a very good event contact is closed. Mine is comfort but after turning off the ignition, when the selector is made, I think this feature had a name for 1 minute to go home with the headlights on. Those who don't know have tried. There are also new things. [/ QUOTE]
`` Follow me home``
08.05.2020 17:11 # 20
xMEGANx
[QUOTE = 307 bursa] [QUOTE = xMEGANx] I rank all the features to the top, guys. Thank you it was really good for the information. = "Cry" />
OK, I added it, I forgot it or it was one of the most important ones.
Page : / 4
