Gears do not change to 1-3-5
08.05.2020 17:26 # 1
CEM206+
Hello guys. When I came from work yesterday, the mule-to-be sounds came from the gearbox and the vehicle does not go to 1.3.5. & Nbsp; 2011 206+ at 29,000
08.05.2020 17:26 # 2
GokhaN
the gearbox is lean and scattered, we will probably help if you bring your car to service.
08.05.2020 17:26 # 3
CEM206+
I do not understand how the 2011 model car will do. Where is your place, your master. I ikitelli org. I'm waiting for the answer from the service. If not, I'll bring it to you.
08.05.2020 17:26 # 4
mrtoknctn
first of all hello I joined the site to answer your question; your
problem is very simple, actually your car is probably out of warranty, so it is not logical to take it to the service, the same thing happened to me in the same event, but my gears never passed (gears mixed up) my gear was missing oil and I had a bit of oil and I broke the gear lever and broke the gear lever in your car broken & nbsp;
2 long and short iron depending on the gearbox I call the gear lever .. longs 1 3 5 short 2 2 and r & nbsp; when someone breaks, the gear doesn't change either to the front gears or to the rear gears & nbsp;
my advice is to weld the arm, I made it for 10 TL and it is not worth the evil eye, I'm still getting it wrong.
08.05.2020 17:26 # 5
CEM206+
Thank you mrtoknctn;
I thought as you said. Actually, I thought that the gear wire would be broken. They searched for Peugeot roadside assistance, they went and they left the car. They left me home. There are 6 months after the vehicle's warranty expires. & nbsp;
08.05.2020 17:26 # 6
mrtoknctn
Glad to be on your behalf your vehicle is guaranteed :) it is possible to get past the warranty coverage in the service.
08.05.2020 17:26 # 7
CEM206+
It was as you said mrtoknctn;
They just called from the service. The gear stick screw came out, so it did not go to 1,3, and 5. The new screws were fixed. : p)
08.05.2020 17:26 # 8
Alicilik
What nonsense. Come on, rubber shock absorber is out of warranty. What does this mean? What is the guarantee, they say, let's search and extend this tool. It also helps friends who can happen.
Alicilik 2013-03-19 10:47:09
08.05.2020 17:26 # 9
mrtoknctn
The work performance of the masters and services .. As I mentioned, my transmission gear was confused, the masters said that the gearbox had come down, of course, I wanted to come to the gas with the warmth of the event, and to whom I told him now, he says that it would not be like that :)
08.05.2020 17:26 # 10
I mean, the gear stick screw is personal error.
