gears and reverse gear problem
08.05.2020 15:47 # 1
tilbe307
friends, my car's gears are difficult. I have a hard time trying to shift it back when it first runs. it passes when I lift my foot from the light clutch and the vehicle sometimes jolts. this does not always happen. why do you think it might be?
08.05.2020 15:47 # 2
Gear shifts are a bit troublesome in pejoes and even make a lot of noise. press the clutch fully. The issue is that you will shift into reverse. At first start or at first, first put it back, then put it back.
respects
08.05.2020 15:47 # 3
tilbe307
I said thank you I wonder if the gearbox oil is diminished. of course if something happens
08.05.2020 15:47 # 4
I changed the gearbox oil recently, just as the chronic chronic is not related to it. I change gear is heard from 20 meters
08.05.2020 15:47 # 5
tilbe307
No, I don't have such a thing, so I'll be thankful and continue on the road :) good night
08.05.2020 15:47 # 6
Goodnight
08.05.2020 15:47 # 7
[QUOTE = tilbe307] friends my car's gears are hard. I have a hard time trying to shift it back when it first runs. it passes when I lift my foot from the light clutch and the vehicle sometimes jolts. this does not always happen. why do you think it might be?
It is no problem if you make Peugeot's gear shifts calm and slow. Especially when reversing, push the clutch fully, without forcing, slowly. If you do not engage reverse gear or are unable to fully engage reverse gear, shift the vehicle to 1st gear and move the vehicle very little and try to stop the vehicle and shift it back into gear.
This is not a malfunction.
It is not a chronic malfunction at all.
The more calm and submissive you treat your vehicle, the less trouble it will cause.
Best regards..
08.05.2020 15:47 # 8
[QUOTE = pugti] ya I changed the gearbox oil recently, just as the chronic chronicle is not related to it. I change gear to be heard at 20 meters [/ QUOTE]
I have a pugti 206 too. 2004 model desire model. There is no problem in transition from 2 to 3, 3 to 4, 4 to 5. but when he throws it from 1 to 2 it is a bit bony. so there is no carting sound. but when you throw it from 1 to 2, it is necessary to pull it to the left. That is, it does not pass from 1 to 2 like oil. There is no problem between 2-3-4-5.
08.05.2020 15:47 # 9
[QUOTE = maverick sbd] [QUOTE = pugti] or I changed the gearbox oil recently, just as the chronic chronicle is not related to it. I change gear to be heard at 20 meters [/ QUOTE]
friends Do you have the situation in me? I mean, before that, I had a lant. Of course, it would pass from 1 to 2 without skating.
When I throw it from 1 to 2, I'm not dead at 206.
08.05.2020 15:47 # 10
Japon
Exactly, I have a problem with me. Normally, I guess it is forcing the pejoes from 1 to 2.
08.05.2020 15:47 # 11
burakdmr
I have the same problem .. There is a problem in the transition to the 3rd and reverse. Especially the reverse gear makes the guy crazy. As if shifting from the 2nd to the 3rd gear, it seems as if there is such a passing ... For this reason: SS:
08.05.2020 15:47 # 12
burakdmr
If I forgot to write, if it does not shift into reverse, if I raise my foot slightly, it passes through the drainage.
