GEARBOX PROBLEM
08.05.2020 16:48 # 1
volkanozkan
HELLO FRIENDS. BEND 307 SW TRIP. BETWEEN HOME AND OFFICE 40km. WHEN THE NORMAL RUNNING TRANSMISSION RISES HIGH SPEED A (130-140), THE SHIFT CHANGES WHEN I SEE 4500-5000 SPEEDS. Sometimes it reaches up to 6000. I WOULD LIKE YOU TELL ME WHAT I NEED TO DO IN THIS TOPIC.
08.05.2020 16:48 # 2
turbo27
The vehicle is caused by the malfunction of the electric motor, which sees the bass of the tripptonic worm and the clutch.
08.05.2020 16:48 # 3
SserkanT
I think the general problem of al4 type gearboxes may be due to the oil being too hot, oil pressure drop, brake sensor, brake bands or selonid valves not working properly. & nbsp; plenty of topics & nbsp;
08.05.2020 16:48 # 4
toga406
Babayigit is wanted to list the reasons and solution of the oil getting too hot.
08.05.2020 16:48 # 5
GiTaRRa
my friend, I hope your problem will be solved, but you need to write in small text, not big text ..
08.05.2020 16:48 # 6
CEM1984
BUY THIS 307 PROBLEM CAR YAHU GO ...
08.05.2020 16:48 # 7
toga406
sat sat sat ugraqsma none ends one starts
08.05.2020 16:48 # 8
ismail ozdemir
Not 307, brother pejos, I enter the forms of such other vehicles, guys, tape, not working, headlight exploded, I don't know what ours is, transmission engine etc ...
08.05.2020 16:48 # 9
toga406
pejoda ha bire al4 or the kind that makes the transmission or electronic problems off
08.05.2020 16:48 # 10
:) it doesn't stop, but I will find a cure for it, let me come to Ankara :)
08.05.2020 16:48 # 11
GANDALF
Guys, this is very, very simple, change the brake sensor, all your problem will be solved and you will pray for me.
08.05.2020 16:48 # 12
GANDALF
[QUOTE = volkanozkan] FRIENDS HELLO. BEND 307 SW TRIP. BETWEEN HOME AND OFFICE 40km. WHEN THE NORMAL RUNNING TRANSMISSION RISES HIGH SPEED A (130-140), THE SHIFT CHANGES WHEN I SEE 4500-5000 SPEEDS. Sometimes it reaches up to 6000. I WOULD LIKE TO TELL ME WHAT I NEED TO DO IN THIS TOPIC. [/ QUOTE] Guys, this is a very, very simple brake switch. ;
08.05.2020 16:48 # 13
serkan206
dear toga406 (experienced member)
`` sell sell sat ugraqsma none ends one '' `
& nbsp; isn't it a shame :)
serkan206 2012-06-11 00:54:43
08.05.2020 16:48 # 14
fTh206
I think the malfunctions vary according to the use of my vehicle. Triptonic gear has failed once in 3 years, the room did not cause any more malfunction from the solenoids, and if you look at it, all brands of automatic gear vehicles are problematic
08.05.2020 16:48 # 15
toga406
Serkan 206 you're right, shame on the field, really. but these chronic costs are endless. I mean, it is not meant to pick someone up. If the field is already checked, get it accordingly. but this pejo will either love the rose and endure or sell it.
3. There is one more option. You take the scrap pieces out, you give the piece to the particle, strong>
08.05.2020 16:48 # 16
foresteng.
[QUOTE = GANDALF] gentlemen this is a very, very simple brake sender, all your problem will be solved and you will pray to me only 20 25 TL, this problem will be solved. . etc. They looked at (Active Iriyil / Istanbul) there was no problem, they even said it was the smoothest and cleanest vehicle we have seen (?). >
08.05.2020 16:48 # 17
toga406
Well, when my car goes to the service, they collect all the bonuses, they think they say ten numbers, they say it's okay. Let's change the oil coolers (no guarantee) / div>
ahh al4 ah
08.05.2020 16:48 # 18
tigerland
Thank God it has been 3 months 3. I did not have any engine or gearbox problems with 206 mi. Little things happened in the circulation billet, tension ball ignition coil, etc. I had no problems with the motor and the walker. Generally, for Peugeot, the walker is broken quickly, of course, it is still a matter of attention.
Continue to Peugeot :)
08.05.2020 16:48 # 19
fTh206
[QUOTE = 206_XS] thank goodness it has been 3 months 3. I did not have any engine or transmission problem with 206? Little things happened in the circulation billet, tension ball ignition coil, etc. I had no problems with the motor and the walker. Generally, for Peugeot, the walker is broken quickly, of course, it is still a matter of attention.
Continue to Peugeot :) [/ QUOTE] Exactly my brother, continue to peugeot If I sell it, I will never buy peugeot again, but I never regret it
08.05.2020 16:48 # 20
berk2309
My teacher, this is why I think it happened in me, when it warms up too much, the traptonic & nbsp .;
Page : / 2
