GEARBOX OIL
08.05.2020 15:24 # 1
ismail ozdemir
2002 MODEL I HAVE 307IM VEHICLES I HAVE TAKEN YOU IN THE TRANSMISSION I HAVE NEVER LOOKED TO OIL, HOW DO I UNDERSTAND OR HAVE A ERROR OR ALWAYS WARNING? DO YOU HAVE A GOOD MASTER TO CHANGE GEARBOX OIL IN ANKARA OR ANY KIND OF AUTHORIZED SERVICE TO BE SATISFIED?
08.05.2020 15:24 # 2
Please write our articles in small letters. Among the forum rules, the related article;
10. Capitalization means shouting. Therefore, it can be used only at the beginning of the sentence.
08.05.2020 15:24 # 3
ismail ozdemir
yell? :) ok I don't shout again
08.05.2020 15:24 # 4
monur
[QUOTE = beyazzzzz] 2002 MODEL I HAVE 307 I HAVE TAKE YOU THE VEHICLE THAT I HAVE NEVER LOOKED TO THE TRANSMISSION OIL. DO YOU HAVE A GOOD MASTER TO CHANGE GEARBOX OIL IN ANKARA OR HAVE ANY KNOWLEDGE SERVICE YOU ARE SATISFIED WITH? [/ QUOTE]
Under normal conditions, if the manufacturer does not interfere with the gearbox for the change of oil, it should be appropriate to change the filter between every 45,000 to 60,000 km and the structure at 100,000 km. The oil you will use is indisputable Mobil LT71141.
08.05.2020 15:24 # 5
ismail ozdemir
my room is about the gearbox, so when I go to change this oil, the master knows, right?
08.05.2020 15:24 # 6
metin
The filter uses metal powders mixed with oil as a result of the abrasions that occur over time in the gearbox as in the engine, of course, it starts to get clogged over time.
08.05.2020 15:24 # 7
ismail ozdemir
thank you I think the best authorized service will handle this job
08.05.2020 15:24 # 8
ismail ozdemir
So when this congestion starts, there will be a problem with the gear changes or the transmission, doesn't it
08.05.2020 15:24 # 9
vbmaster
You can understand the gears ...
08.05.2020 15:24 # 10
ismail ozdemir
thank you
08.05.2020 15:24 # 11
vbmaster
Unless there is a problem with the gearbox, if you have just touched it, change it if you have entered the pad or something, or I would say touch it. Accident-free days ...
08.05.2020 15:24 # 12
furkanbaki
Last week, I changed 206 in terms of gearbox oil, but they did not say that there was no filter or oil filter, but there was something called gearbox oil filter in 206's
08.05.2020 15:24 # 13
ismail ozdemir
I don't have a transmission problem, thank goodness car triptonic, are there any pressure pads in them?
08.05.2020 15:24 # 14
metin
[QUOTE = beyazzzzz] I don't have a transmission problem, thank goodness car triptonic, do you have pressure pads in these too?
no. there is hydraulic.
08.05.2020 15:24 # 15
monur
[QUOTE = furkanba that]
That filter is not like a motor oil filter. It is a big box of metal under the gearbox. If your vehicle is not 150,000 km, it does not need to be changed.
08.05.2020 15:24 # 16
hhuzun
If there is no problem in your car, don't play. When I bought it like you, I wanted to have it serviced, and they had a car at the bass dealer.
