Gearbox Faulty Error ??
08.05.2020 17:01 # 1
kuantum
In the morning, when my vehicle was going uphill, I gave this error for 2-3 days and started to turn on the malfunction lamp. My vehicle alone has the 2006 model SW 307 and a new type of solenoid. Does the fact that the solenoid does not have the old type solenoid in 2005 & nbsp; and earlier models show that the problem still arises from the solenoid valve? So although it is a new type solenoid valve, it is still broken, so it might be failing? According to him, I am thinking of renewing my solenoid valves.
08.05.2020 17:01 # 2
It is very difficult to say that. Connect your most robust vehicle to a computer and see what causes the error. & Nbsp;
08.05.2020 17:01 # 3
msertkol
I have morning too. My car is LPG. It does not exceed 2 minutes, and automatic gearbox defects and shakes. I detected a collation between the temperature and the gearbox. When the engine is cold, the transmission fails during the transition to LPG. For now, I go in the morning for 2-3 minutes, then switch to LPG manually. It's not a problem. The automatic gearbox fault error did not occur. As a solution, to increase LPG transition temperature in BRC service a little.
Regards.
08.05.2020 17:01 # 4
kuantum
[QUOTE = msertkol] I have morning too. My car is LPG. It does not exceed 2 minutes, and automatic gearbox defects and shakes. I detected a collation between the temperature and the gearbox. When the engine is cold, the transmission fails during the transition to LPG. For now, I go in the morning for 2-3 minutes, then switch to LPG manually. It's not a problem. The automatic gearbox fault error did not occur. As a solution, LPG is to increase the transition temperature a little in BRC service. div>
08.05.2020 17:01 # 5
msertkol
I re-adjusted the BRC service. & nbsp; Burning temperature was too low. It is set at 45 ° C. When I start the car, I try again and send a message. I will not take the car tomorrow, but I have to go to school.
I will try and give information at a suitable time ..
08.05.2020 17:01 # 6
msertkol
My problem has been solved. BRC service adjusted LPG transition temperature to 45C as I said. The car did not show an automatic gearbox error.
FYI, respect.
08.05.2020 17:01 # 7
katipahmet
The solution to this job is to have it connected to a PC and checked it. Then you should evaluate what you have to do according to the result on the pc. So we can't say anything about electro valves directly. & Nbsp;
08.05.2020 17:01 # 8
kuantum
connected to pc, can anyone evaluate: & nbsp; http: //forum.peugeotturkey .com / forum_posts.asp? TID = 24710 quantum 2012-11-27 09:46:04
08.05.2020 17:01 # 9
msertkol
I suggest you read a comment on "quantum". & Nbsp;
http://forum.peugeotturkey.com/forum_posts.asp?TID=24710&PID=386593񞘡
Do you have the same symptoms as well?
