Gearbox
08.05.2020 20:49 # 1
Uyanoglu
Everyone. A friend I'm new in form I need help I have a 2005 model premium automatic transmission vehicle I just bought it but now I have encountered a problem when the car was passing two, it was filling and unloading. They give you price from 1500 to 3500, what do I do? Thank you in advance for your help.
08.05.2020 20:49 # 2
Welcome, sir. I wish you to use your vehicle without any accident, good luck. problem classic al4 transmission problem. a good master needs to find out who understands this gearbox, usually the problem of changing solenoid valves and transmission oil disappears. these are where the gearbox oil filter is removed. And those who are on the hydraulic block may also have a problem. worst 700-800 TL.
08.05.2020 20:49 # 3
Uyanoglu
Tşkler. My brother and sister, they attached seven to eight hundred bidets to the machine, they gave a lot of error codes to find that master in Konya, I read the important form. There are such problems.
08.05.2020 20:49 # 4
you are welcome, bro, do you know what the error codes are?
08.05.2020 20:49 # 5
Uyanoglu
These are the codes. Mix regulation autoadamantation mix too weak. # mini. Fuel level plus short circuit or open circuit. # Setting the vehicle speed consistency. # can motor information / no signal intermittent error. # multifunction switch foul. # vehicle abs speed transmission continuous error. Help me, bro, what about these?
08.05.2020 20:49 # 6
I have a few more questions first. Is there any LPG in the vehicle and extra, like exnon or sound system. There are also codes like p0112 in the article, brother, can you write them. many of these errors may be interconnected.
The multifunction switch fault error is caused by the part in the link below.
08.05.2020 20:49 # 7
Uyanoglu
Bro you are great There are LPG and extra Zen music cables and stuff in the trunk P2191. P0463. P0571 there is what the device in the link is
08.05.2020 20:49 # 8
bro, now i will leave work, tomorrow my answers are all Smile I can't be available in the evening.
08.05.2020 20:49 # 9
Uyanoglu
Ok brother i will wait cvb i hope i thank you
08.05.2020 20:49 # 10
Uyanoglu
Hello brother! What did you do
08.05.2020 20:49 # 11
KILIC
I couldn't understand exactly what it was like when I was going from 1 to 2. But if you look at the error codes, your brake sensor seems to be faulty. In the meantime, I suggest you have your Lpg settings checked. It can also be problematic where you take the fuel. Do you have a hard time getting the gear from Dye P, by the way, do you get stuck?
08.05.2020 20:49 # 12
Uyanoglu
There is no difficulty p, while passing from d to d, while my master is moving with d, he is knocking while passing by, according to the master, he said, he passed on two and took the bosa and went back to another, in another master, if he did not break the diphenous Ded, the bisey Ded.
08.05.2020 20:49 # 13
[QUOTE = Uyanoglu] Brother Hello! What did you do [/ QUOTE]
Brother, I haven't had the opportunity to look at the courts or have been busy at work for two days. The brake sensor that you call our friend is probably a cheap piece of defect - the gas pump is broken and the pump is broken. The automatic transmission contactor that I call it cuts the electricity when the gear is in D or R when you start the tool and prevents the vehicle from starting. It also turns on the reversing lamp when it engages reverse gear and works to convey the position of the gear to the indicator.
sonerkyl 2018-03-30 17:47:31
08.05.2020 20:49 # 14
Uyanoglu
Brother dun went to a gearbox Ded said from the brain in the gearbox related to the knock, what is he going to do? Respects
