gearbox
08.05.2020 14:59 # 1
seytan kirmizi
hello, I have a triptonic 307, m, but it has been hitting the gears for a while, sometimes it took me a few minutes to get to the service, they said that the gearbox revision is required. I would appreciate if you help.
08.05.2020 14:59 # 2
furkan
nothing happens, this is the problem of the automatic
08.05.2020 14:59 # 3
Haksen016
You haven't written the mileage of your vehicle, if the oil change is not a remedy, then the selonoid valves will probably need to be replaced.
08.05.2020 14:59 # 4
selfat8
There are ready discounts, it costs 350 TL, says friends selo + yag + software + workmanship
08.05.2020 14:59 # 5
kidnapping the last days mine will change it chronically
08.05.2020 14:59 # 6
bayelektronik
Since I changed the selenods, the satisfaction of the car has changed even in the ramps.The cold engine does not listen to the ramp.
08.05.2020 14:59 # 7
ali oncu
if it is 350 in service i think it is guaranteed to miss
08.05.2020 14:59 # 8
seytan kirmizi
transmission oil changed 2 times 2004 model 88bin car
08.05.2020 14:59 # 9
Onur
probably one of the solenoids
08.05.2020 14:59 # 10
Haksen016
then the selonoid valves will change brother, if I am not mistaken, in many automatic peugeot cars, these valves have changed somehow, some parts said it was problematic, some said the valves will expire after a certain period of time, etc. but these valves eventually change in automatic peugeot, of course there may be exceptions.
08.05.2020 14:59 # 11
Onur
including mine will change Sırıtma These valves are generally said to be faulty. It is not known how accurate it is. There are new valves now. Let's see.
08.05.2020 14:59 # 12
Haksen016
I am very pleased to change it in the forum, these valves are the original peugeot parts or I am throwing a good brand like a bosch. Because I will change it.
08.05.2020 14:59 # 13
Onur
I know that it is not a part that peugeot made by itself.
08.05.2020 14:59 # 14
Haksen016
In the last forum, our friend named bayelelektronik had changed, he can tell us the exact origin and brand of the piece.
08.05.2020 14:59 # 15
Haksen016
Sorry I misspelled our friend's nickname bayelektronik.
08.05.2020 14:59 # 16
bayelektronik
My teacher solenoids are produced by peugeot and citroen.brog wagner type black connector. Now I'm not saying that you are banning the gas on the slope. Thank God Allah. I love you solenoid changed 307 Heart
bayelektronik 2010-12-05 18:20:14
08.05.2020 14:59 # 17
06ef
Hello friends, I have 307 triptonics in 2003 96 thousand. On fast starts, it shifts with knocking at high speeds and it says automatic gear fault. Transmission oil has changed but again it did. Is this related to solenoids or do you know what should I do?
08.05.2020 14:59 # 18
seytan kirmizi
Many thanks for the information you provided. I wonder how much it would cost to change these cellophoids.
08.05.2020 14:59 # 19
Haksen016
My friend named 06ef yes, you are from us, the way to change the selonoid seems to you.
08.05.2020 14:59 # 20
Haksen016
exchange cost between 500 and 450 ytl. There are costs between according to the service. double cellophane valve + oil change + workmanship.
Page : / 2
