gearbox
08.05.2020 15:44 # 1
berk2309
my friends, my car's solenoids have changed, knocked on, okay but now when I stop at the hill, the car does not crawl, I am stepping on the gas, it does not go
08.05.2020 15:44 # 2
printing pad ??? how about ??
08.05.2020 15:44 # 3
berk2309
Do you have a pressure pad in automatic gearbox :)
08.05.2020 15:44 # 4
my head was so tired today it seems Sırıtma I'm sorry .. the head went well ..
you by_ 2011-07-02 14:57:36
08.05.2020 15:44 # 5
berk2309
no problem happens like this: D
08.05.2020 15:44 # 6
No? So who is doing the task of separating the thrust pad in the automatic gears with the gearbox?
[QUOTE = berk2309] automatic gearbox, whether there is a press pad :) [/ QUOTE]
08.05.2020 15:44 # 7
berk2309
torque converter, no press pad :)
08.05.2020 15:44 # 8
metin
[QUOTE = Menderes] No? So who is doing the task of separating the thrust pad in the automatic gears with the gearbox?
brother does not separate, turns with a motor, different to grip, but there is no pressure on the pad (:
08.05.2020 15:44 # 9
metin
You press the gas, the roof doesn't go away.
When you take your foot off the gas while you are on the road, will the pointer come down slowly with the compressor or do you suddenly fall?
08.05.2020 15:44 # 10
berk2309
The cycle is falling fast.
08.05.2020 15:44 # 11
berk2309
can it be from torque converter
08.05.2020 15:44 # 12
My age is anyway. I learn more. Dil Çıkarma Thank you.
[QUOTE = text] [QUOTE = Menderes] No? So who is doing the task of separating the thrust pad in the automatic gears with the gearbox?
08.05.2020 15:44 # 13
[QUOTE = berk2309] torque converter available no pressure pad :) [/ QUOTE]
+ 999 Thumbs Up
08.05.2020 15:44 # 14
ramtas
If I ask something, if the cycle is falling fast, it is not proportional to the speed.
08.05.2020 15:44 # 15
alisuat
sometimes it happened to me but he did it 1-2 times then passed when he was about to stop on the hill, he pressed the car to the full throttle, then he stopped and hit it very hard but he did it 1-2 times a year ago, it was very interesting that he did not go, I did not understand the event of the fall, I would be glad if you open it fully
08.05.2020 15:44 # 16
peugeot murat
Does the vehicle have LPG? If there is any mixture failure, it may cause no gas to be consumed on departure or if the coil failure in LPG will do the same thing.
08.05.2020 15:44 # 17
ramtas
[QUOTE = text] you are pressing the gas, how it doesn't go.
I was wondering why.
08.05.2020 15:44 # 18
GANDALF
[QUOTE = ramtas] [QUOTE = text] you are pressing the gas.
I have the same problem in my car, the cycle goes up and down fast gas pressure ... sometimes it doesn't go into gear, it stays at the d and stays on triptonige, but it stops flashing .. but there is no problem in the trip computer. could the problem be with the speed sensor .. it looks like something related to speed
08.05.2020 15:45 # 19
berk2309
I went with friends, there are masters familiar with abc pejo every time they are cheaper, man tested, the converter is running, I will fix it, I will repair it.
08.05.2020 15:45 # 20
berk2309
The master turc (torque converter) of the abc pejoda do not fill the pressure, the pressure is less said it will hurt, the cheaper way, we will handle it in a way that it will be so cheap
Page : / 2
