Gear Stuck Relief Help
08.05.2020 20:07 # 1
OguzhanKucuk61
In congested traffic, as they proceeded with intense stop-and-go, the temperature was going around 95-100. I had to use 1st and 2nd Gear continuously. I stopped at a Light, wasted and when I moved, the gear did not change to 1. I took it off the clutch and pressed it again. It happened to me once again and then it improved when I stopped and started it again. This time, I stopped it and started it again, it did not go from idle to 1 again. While working, I got out of the vehicle and pushed to the right of the road. When I tried again, the gear went smoothly. Why might he have done this? Could there be a problem with the printing pad replacement? It had changed about 4-5 thousand km ago, and after it was changed, the gears became harder than I had. I'm waiting for your help.. oguzhankucuk61 2016-12-31 22:58:51
08.05.2020 20:07 # 2
ALLEX
Although my brother is unlikely,
Have the clutch fork checked. You'd better share the result.
May Allah not cause any trouble.
08.05.2020 20:07 # 3
OguzhanKucuk61
Okay, dude, I'll see a master.
Amen brother amen
08.05.2020 20:07 # 4
just like oguzhan have the clutch fork and gear ropes checked.
08.05.2020 20:07 # 5
OguzhanKucuk61
Ok brother
08.05.2020 20:07 # 6
pepecura
When I stay in a lot of traffic, the pedal hardens in me. Mine is not stuck yet, but is it normal to harden?
08.05.2020 20:07 # 7
OguzhanKucuk61
Hardening and grip above is a sign that the pad has reached its lifetime.
08.05.2020 20:07 # 8
pepecura
[QUOTE = OguzhanKucuk61] Hardening and grasping above indicate that the pad is at the end of its life. [/ QUOTE]
Together with the flywheel, it was 5000 km.
08.05.2020 20:07 # 9
OguzhanKucuk61
I went to the master yesterday, I explained the situation. I shared with the master that the gear that happened to me on the 2nd Campaign remained stuck and that the clutch suddenly shifted up while in reverse gear. The mast decided to replace the clutch wire. He did not allow anything else. He said that even though I insist that we should not change it in vain, it would be that there was no other problem based on what I said. The original part came to 65₺, the change was made. He said he would take 35₺ labor. Completed to 100 again :) I felt like the pedal softened after the change. I did not make much progress, I do not know if I will have the same problem in the future. But it feels like a wire to me. If I have the same problem again, it will be a pity to the wasted wire change.
08.05.2020 20:07 # 10
KILIC
I hope you don't live
08.05.2020 20:07 # 11
pepecura
I benefit from changing the clutch wire
I think it will be soft when I go to maintenance in summer, I hope :)
pepecur to 2017-01-09 14:51:57
08.05.2020 20:07 # 12
OguzhanKucuk61
I thought the wire change would also take the Pedal working gap, but unfortunately it is the same. And the master said that he is self-adjusting, and the fact that the grip point remains the same without any adjustment confirms this view.
