Gear shifts
08.05.2020 16:25 # 1
Ucyuzalti
Friends & nbsp; Shifting to 1st gear when starting the car for the first time becomes difficult & nbsp; mesala car & nbsp; with & nbsp; I wake up & nbsp; more & nbsp; After & nbsp; is again from 1st gear & nbsp; My ancestors & nbsp; where appropriate & nbsp; When & nbsp; I'm having trouble pushing & nbsp; the gear does not engage when it gets hot & nbsp; cutting, & nbsp; reason & nbsp; what, normal & nbsp; a & nbsp; Is it the case?
08.05.2020 16:25 # 2
[QUOTE = three hundred and sixty of] Friends & nbsp; Shifting to 1st gear when starting the car for the first time becomes difficult & nbsp; mesala car & nbsp; with & nbsp; I wake up & nbsp; more & nbsp; After & nbsp; is again from 1st gear & nbsp; My ancestors & nbsp; where appropriate & nbsp; When & nbsp; I'm having trouble pushing & nbsp; the gear does not engage when it gets hot & nbsp; cutting, & nbsp; reason & nbsp; what, normal & nbsp; a & nbsp; Is it the case? [/ QUOTE]
1. Is the vehicle in motion while trying to shift into gear?
08.05.2020 16:25 # 3
Ucyuzalti
yes & nbsp; On the move, I press the depression while I get warm in the 2nd line 1. the 1st atacam & nbsp; time does not pass, when it is forced, it passes, and when the road passes, 2 km or so problem is getting better & nbsp;
08.05.2020 16:25 # 4
___KxL___
The same problem exists in my vehicle. As he said in his friend & nbsp; after a while there is nothing, he passes very easily
08.05.2020 16:25 # 5
The 1st gear is the take-off gear.If it is not mandatory to shift into 1st gear while the vehicle is in motion, it is a situation to be avoided. If it is difficult, this time there is something wrong.
08.05.2020 16:25 # 6
[QUOTE = three hundred and sixty of] yes & nbsp; On the move, I press the depression while I get warm in the 2nd line 1. the 1st atacam & nbsp; time does not pass, when it is forced, it passes, and when the road passes, 2 km or so problem is getting better & nbsp; [/ QUOTE]
This is perfectly normal. You should not try to force 1st gear while on the move. Either you should stop completely and put it in 1st gear, or continue from second gear. I recommend not to push too hard.
08.05.2020 16:25 # 7
Ucyuzalti
I do not force, unless you have a hard time buying, completely & nbsp; I stop and pump the drain into gear
08.05.2020 16:25 # 8
Ucyuzalti
Thank you for your answers, friends.
08.05.2020 16:25 # 9
peugeotefe
It is normal that it does not go into 1st gear while you are walking, but if you are in stop-and-go traffic, if your speed is in 15s, it shifts to 1st gear when it warms up, it turns back to normal.
08.05.2020 16:25 # 10
Ucyuzalti
The oil of the gearbox has just changed, they put the thick oil, I bought it in the oil, though I said I will buy the gearbox oil, he gave it to the master, he said to the master, this will not happen, he said, take the gearbox oil. Threefacealt 2011-12-05 21:54:13
08.05.2020 16:25 # 11
yavuz25
[QUOTE = Three Hundred Six] The oil of the gearbox has just changed, they put in the thick oil, I bought the oil in the oil, though I said I will buy the oil, he gave it to the master. [/ QUOTE]
Park in the evening, start by pressing the clutch in the morning. Let the oil wait for a full night, but then release the clutch while the gear is idle, let the handbrake down, and the car will move clearly oil is thick. But I know that the gearbox does not accept every oil, it should be the number number. "Wink"
08.05.2020 16:25 # 12
Ucyuzalti
The car now moves anyway on a sloping ground "Smile", the best experience in a flat place. Millet engine heating in my gearbox cam & nbsp; "LOL"
08.05.2020 16:25 # 13
yavuz25
Of course it is important to be in the flat area. Brother, do the test I said, whether the car is going or is it standing? "Smile" By the way, it's easier to warm up the transmission. "LOL"
08.05.2020 16:25 # 14
Ucyuzalti
What was the scene of shooting the car up and down, there is no place when I look at the street & nbsp; There is no parking space even in between. Bidder diolar crisis exists "LOL" should not walk now
08.05.2020 16:25 # 15
yavuz25
[QUOTE = Three hundred and sixty] What was driving down and down the car, there was no place to look at the street & nbsp; There is no parking space even in between. Bidder diolar crisis exists "LOL" should not walk now [/ QUOTE]
what is the correct word. you will try it tomorrow this day, brother. "Wink"
08.05.2020 16:25 # 16
yavuz25
What happened?
08.05.2020 16:25 # 17
Ucyuzalti
I could just get straight to the level, clear tomorrow & nbsp; "LOL" & nbsp;
08.05.2020 16:25 # 18
yavuz25
ok. "Smile"
08.05.2020 16:25 # 19
ercan_g
Look at it, I put the pressure pad set to zero, I have the same problem with me. But as friends say, since the oil is probably close to 0 degrees cold at night, the thick oil freezes very quickly, which can make the gear shift difficult. the same problem does not happen in summer, for example
08.05.2020 16:25 # 20
Ucyuzalti
I understand that the oil that I understand will cause a heavy damage.
Page : / 2
