Gear shift triptonic
07.01.2021 21:05 # 1
Yasarkys
He gets stuck by switching gears, he doesn't see the triptonic, he sometimes gets into normal and sometimes he screams like idle while accelerating, what could be caused by what I showed the gearbox, they said no problem.
07.01.2021 21:10 # 2
muzzy35
And hello, get well soon
07.01.2021 21:14 # 3
Yasarkys
Hello, thank you. If you have experience on the subject, I would appreciate it if you help. 2003 307 1.6 xt
11.01.2021 14:05 # 4
Safatugan07
Hello teacher. I also had trouble because of the gear shifts. There was a force in 1, it was very difficult in the reverse gear, it sounded like gart, you think I am eating the pressure lining gears. I'm new in Ankara, I went to a master according to the suggestions. Yaren Peugeot Ali is a master. He turned the original unadjusted clutch wire into a short adjustable one. It was a zero car clutch, the gears are also very nice. My problem was like this and I solved it. My vehicle is 106 xr 98 model. Take it to the master I said if you were in Ankara or something. He is a very practical man. It's not familiar or anything, misunderstanding, I researched a few people from the forums, I wanted to try them and they did a very good job. I gave 100 TL to 100 TL workmanship on the tele and adjusted it to 200 TL. The owner, whose vehicle I just bought, told me that another part will be changed, from master to master. If there are problems with gear shifts, I can offer you such a suggestion. Get well again.
11.01.2021 17:34 # 5
KILIC
The pads in the automatic gear may be missing When driving on the road, the vehicle suddenly falls idle. The engine screams but it does not go, then it starts to go with a knocking.
