Gear Shift Knob Flickering and Shaking in the New 2008
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 2008
24.12.2020 23:34 # 1
mete33
Hello Guys, There are vibrations and wobbling (parallel to the accelerator and brake) in the gear knob, which I felt at the first traffic exit in the 2020 Model 2008, which I bought yesterday, and then definitively diagnosed in the test drive. Today, when I went to the service, the service officer noticed the situation and shot the file on the camera. If anyone had such a problem before, what kind of solution was produced.
25.12.2020 02:04 # 2
evcimenkaktus
I felt it for a moment when I received it today, but the traffic was very intense, I used a little distance and left it to the master for ceramic coating.
25.12.2020 08:04 # 3
mete33
Good luck to you too. It is very obvious in 4th gear and 2000 rpm
25.12.2020 13:01 # 4
I think it should not be like old type vehicles, after all, this gear mechanism is the first time I hear from you.
25.12.2020 13:20 # 5
mete33
As the force you give to the engine increases, the vibration increases even more and when you pull the gas, it moves forward as if you will shift. The file is opened let's see what will come out
25.12.2020 15:20 # 6
they will probably change the gearbox or engine mounts first.
15.01.2021 12:10 # 7
evcimenkaktus
[QUOTE = mete33] As the force you give to the engine increases, the vibration increases even more. The file is opened, let's see what will come out [/ QUOTE] I hope there was no problem.
