Gear Shift in Automatic Gear
08.05.2020 18:18 # 1
MuratUnver
Friends Slm,
My vehicle is 2009 model 1.6 HDI 308. I have been driving for 7 months and 85 thousand. I am very pleased with the performance, but when using the car automatically, it feels a bit too much especially when shifting from 1st gear to 2 and 2 to 3 while shifting the gears, but most importantly, when falling from 3 to 2 and from 2 to 1 gear, as if the speed in the manual car is not fully reduced As if I put it on my feet and clutched my clutch, the car pretends like a proposal, and the cycle goes up to 2000 when it drops to 1500. This can cause. Are there friends who have the same problem or the same situation if it is not? Can anything be done to fix this?
I request your help. Thanks in advance.
08.05.2020 18:18 # 2
kivanc
[QUOTE = MuratÜnver] Friends Slm,
There is nothing to do with normal gear shifts as it rises. I use manual f1 mostly, I feel the transitions less and I am prepared because I made that transition myself. If you go down the slope while passing from 3 to 2 and 2 and you do not press the gas, then the vehicle will be in the clutch and if you press the azck gas, the clutch will pull out and you will experience the situation. If your vehicle has f1, I suggest you use it from there. I usually live in me but I feel less with gas games transitions.
