gear shift difficult
08.05.2020 17:59 # 1
ozncnercn
We said, we uploaded the pictures, I don't know if it was worth it, even when it is hot in the morning and I have a problem with the gear changes while my car is running only one star, I think it is very hard when lowering the gear but I started to climb slightly. Tongue If anyone knows what has happened to you, can someone help or sprinkle water on it because it's cold? Big smileLOL
08.05.2020 17:59 # 2
emre_akdag
I have the same problem. when the weather gets cold, cracked noises come. sometimes it can be difficult to pass. normal;)
08.05.2020 17:59 # 3
Serkan
Normally, it is normal that the gear changes are a little harder in the cold.
08.05.2020 17:59 # 4
ozncnercn
this was the case that scared me, the gears are so soft that i can't tell you, there is no hardness like gear oil, i called the old owner today, he said he changed the gearbox oil today thank you for checking it :)
