gear ranges
08.05.2020 14:14 # 1
cevdet
Hi friends. I am among you as a user of 2006 model 307 1.6 hdi sw starting from today. but this is the first time I use a diesel vehicle. I don't know if I was good at buying a diesel or not, but all I know is that I don't know much about diesel. Therefore, I need the knowledge of valuable friends who have knowledge about this subject. especially the gear ranges and of course, after which revolutions should be changed. thanks in advance for your answers ...
08.05.2020 14:14 # 2
acad
Good luck my friend, use the 307 diesel between 1500 and 2500 cycles, you will keep the fuel to a minimum and extend the life of your engine,
08.05.2020 14:14 # 3
cevdet
acad brother thank you for your answer. but there are many different opinions. 3500-4000 cycles are mentioned. If it will be used at 3500-4000 revolutions, diesel saving will not be possible. because fuel consumption at 3500-4000 revs is max. then it consumes even more than gasoline. respects...
08.05.2020 14:14 # 4
Long Beach
you already gave the answer yourself Thumbs Up
08.05.2020 14:14 # 5
H-a-d-i
you can also follow the trip computer, after 1 week follow your ear gets used to the engine sound. according to him, you throw gears. Do not exceed 3000.
08.05.2020 14:14 # 6
2500 u overnight. I am doing ole, I am satisfied with the fuel, you can press it according to your place :)
