Gear problem while vehicle is moving
Homepage » PEUGEOT MODIFIED PLATFORM » 307
08.05.2020 18:11 # 1
samet206
Good evening, friends, I have 206 vehicles, the pad has changed in August 2013, at first, it caused some problems, but later when I changed the gearbox oil again, some parts were lubricated and improved, but today I realized that the vehicle goes into gear without pressing the clutch.
samet206 2015-06-16 23:54:34
08.05.2020 18:11 # 2
kursat3006
I did not see an abnormality. While the car is not working, the gear will pass without pressing the clutch, but it will be harmful.
08.05.2020 18:11 # 3
Sir, where is the problem? When I was less than 10 years old, I would do it from playing a car and now if you do it, every car will be :) :) It only damages the gears. There is no problem in your car. :)
08.05.2020 18:11 # 4
samet2461
This is the first time I've heard of such a thing. Of course, the gear changes when the car is at a stop. There is no abnormality from this. even in diesel vehicles when moving, the gear can be changed without pressing the clutch when it catches the cycle. If the gearbox is broken, the vehicle will move out of gear while it is understood what science makes sound. no problem bro Smile samet2461 2014-01-09 18:52:49
08.05.2020 18:11 # 5
rizeli_53
no problem, rest your head
08.05.2020 18:11 # 6
samet206
I read the comments of friends, I was relieved, I know the conversation of passing the gear without hitting the clutch in the diesel vehicles.
samet206 2015-06-16 23:56:01
08.05.2020 18:11 # 7
Even if it does, there is no breakage. These are things that will happen over time. So it won't be good in the long run.
08.05.2020 18:11 # 8
samet206
Even if [QUOTE = dogancanguden] does not break. These are things that will happen over time. It won't be good in the long run. [/ QUOTE]
Thank you, I already thought there was a problem and I tried several times. What is this?
08.05.2020 18:11 # 9
Turgay_66
When I was a kid, I would play with my grandfather's tractor LOL
08.05.2020 18:11 # 10
samet206
[QUOTE = Turgay_66] When I was little, I would play with my grandfather's tractor gear LOL [/ QUOTE]
Teacher, if it is a tractor, my dear 206 Big smile Since I did not come to my head before, I was struggled to learn it like this. What do we do?
08.05.2020 18:11 # 11
A normal situation is this problem.
08.05.2020 18:11 # 12
samet206
[QUOTE = Moondust] It's a normal situation this is OK. [/ QUOTE]
Thank you for your answer.
08.05.2020 18:11 # 13
Serkan
Let me relax you a little bit, Samet, it is perfectly normal :)
08.05.2020 18:11 # 14
samet206
[QUOTE = Serkan] Let me relax a little bit, Samet, it's a normal situation:) [/ QUOTE]
Thank you, I love this forum, it teaches me a lot :)
08.05.2020 18:11 # 15
ahmet_bjk
[QUOTE = samet2461] this is the first time I've heard of something like this. Of course, the gear changes when the car is at a stop. There is no abnormality from this. even in diesel vehicles when moving, the gear can be changed without pressing the clutch when it catches the cycle. If the gearbox is broken, the vehicle will move out of gear while it is understood what science makes sound. no problem bro Smile [/ QUOTE]
Why is it not in gasoline if it is in a diesel vehicle? I know that the gearbox will not differ in gasoline and diesel vehicles.
