Gear panel has straight dashes (boite automatiqe)
11.10.2021 21:17 # 1
Cmylmz01
I have a Peugeot 307 2004 model car.
My problem is that there is a straight dash where dprn should be written on the gear indicator, and the car is losing power
Something like Boite automatic is written on the panel
The automatic transmission is considered new 1.5 2 years old.
div>
I had a similar problem before, something like the gearbox rope (I can't remember the exact name) got loose and tightened it up. After 8 9 months, I didn't have this problem.
What is this problem, what should I do, hello to the automatic transmission guy If I give 500tl
I would be very happy if you have a good Peugeot mechanic suggestion for Adana.
I couldn't add a photo from the wire< /div>
12.10.2021 17:51 # 2
muzzy35
I had a similar experience when I cleaned the socket of the automatic transmission brain and put it back, it was fixed. It's been a year and it didn't cause any problems
It must be behind the battery and fuse box, maybe the sockets are oxidized, you can do it at least once, it's worth trying
