gear knob
08.05.2020 14:06 # 1
asil 206
Guys, I bought a shift knob for 206, but I couldn't dismantle the old one, does anyone know how this gets ripped off? Thanks for your help already ...
08.05.2020 14:06 # 2
MirakGTI
Turn it to the right and to the left, it must come out or do it right and right.
08.05.2020 14:06 # 3
asil 206
If you said so, this will definitely remain in my hands .... no screw or something?
08.05.2020 14:06 # 4
master
[QUOTE = noble 206] this is what I have said, it remains in my hands .... what is a screw or something, right? [/ QUOTE]
insert the bellows, there is a ratchet inside, cut it, turn the knob to the left and right and remove it.
08.05.2020 14:06 # 5
asil 206
[QUOTE = master] [QUOTE = noble 206] you have said that this is definitely in my hands .... what is a screw or something? [/ QUOTE]
insert the bellows, there is a ratchet inside, cut it, turn the knob to the left and right and remove it. [/ QUOTE]
When I say crickets,
08.05.2020 14:06 # 6
master
[QUOTE = noble 206] [QUOTE = master] [QUOTE = noble 206] this is sure to remain in my hands when you say that ... what is a screw or something? [/ QUOTE]
[/ QUOTE] exactly ...
08.05.2020 14:06 # 7
master
[QUOTE = master] [QUOTE = noble 206] [QUOTE = master] [QUOTE = noble 206] whatever you said, this one will remain in my hands .... bi screw or what is it? [/ QUOTE]
[/ QUOTE] exactly ... [/ QUOTE]
I even plan to shorten the gear lever with the saw if I set the time.
08.05.2020 14:06 # 8
asil 206
not a bad idea
08.05.2020 14:06 # 9
GokhaN
you will have problems when trying to disassemble at all. There is a plastic underneath the gear knob, which often breaks when removing the room from the knurled section. If you want to renew it, I recommend you to install 206 gt or 206 rc gear knob. I will shorten the gear knob, the gears are too long, there is nothing to do in the shipyard, there is nothing to do, you will hang and break it.
08.05.2020 14:06 # 10
hasimayaz
It is available on Ebay with its shortened arm and head, but I don't know if they're selling TR.
If I remember correctly, you were turning 90 degrees clockwise and up. It may be the opposite. I couldn't remember exactly. It is already turning in only 1 direction. You will just turn 90 degrees.
hasimayaz 2009-11-17 16:07:57
08.05.2020 14:06 # 11
asil 206
okay, as you said, I had to turn it 90 degrees and pull it up hard, but attention was low, I was breaking my nose.
