gear knob
08.05.2020 16:11 # 1
sezar206
Hi guys, I can't disassemble the original gear knob in my car. After inserting the gear guard, I lowered it and tried to turn it left and right under the gear knob, but it did not. I haven't seen any bolts. & nbsp; Can I help me if I have a friend who made this application before?
08.05.2020 16:11 # 2
zavur
I changed, but I did not disassemble, behaved a little hard, broke, did not come out, because he got angry & nbsp;
08.05.2020 16:11 # 3
sezar206
I understand. There was no problem installing the new one after breaking the old one, right?
08.05.2020 16:11 # 4
zavur
No, I bought the gear knob, it was a sports style, called the universal product, so it fits every vehicle. There were 4 plastic molds, whichever of them was fit, then you put on the gear knob and fastened it with a screw on the side.
08.05.2020 16:11 # 5
Burak07
After removing the screws from the bellows, hold the knob and turn it to the left and pull it out.
08.05.2020 16:11 # 6
zavur
be careful not to fit the shape of the plain knob on your side, be careful not to sit well in your hand, otherwise the problem has happened in my previous car I had dismantled & nbsp;
08.05.2020 16:11 # 7
sezar206
I guess not ole, because I couldn't see it in 206 because hic
08.05.2020 16:11 # 8
Ozgur
you turn it 90 degrees to the right and it comes to your hands.
08.05.2020 16:11 # 9
Burak07
[QUOTE = fatihpekgoz] I guess it is not ole, I could not see the cunki vada in hic
under the bellows, you can remove the lower bellows layer.
08.05.2020 16:11 # 10
sezar206
I tried to turn it to the right and left, but it does not play from anywhere. I did not force it.
08.05.2020 16:11 # 11
I don't think it will take a lot of money to take it to someone who understands it. It will be bad if it breaks as a result, it may be necessary in the future original bun.
08.05.2020 16:11 # 12
djchaos
[QUOTE = fatihpekgoz] slm friends I can't disassemble the original gear knob in my car. After inserting the gear guard, I lowered it and tried to turn it left and right under the gear knob, but it did not. I haven't seen any bolts. & nbsp; can I help me if I have a friend who has done this application before?
08.05.2020 16:11 # 13
kaderim@61
friends, I changed my gear knob, it was broken upwards, it was a little stronger.
08.05.2020 16:11 # 14
Ozgur
peugeot original 206 gear knob 30 tl ... original as well.
even the original rc metal knob is not 150 tl. How did you get it out 150? ?? :) When turning the
, the actual upward comes.
08.05.2020 16:11 # 15
GokhaN
First, remove the bellows from the bottom, then you can easily unscrew it by half a turn and half a turn.
08.05.2020 16:11 # 16
sezar206
I tried but I couldn't. I went to the electrician and he said, but I said I might have to break it. Unfortunately, I had the knob on the net. left footrests and pedals are ok but I couldn't handle the knob. I tried to flip but did not roll.
08.05.2020 16:11 # 17
sezar206
I tried it again and it happened :) when you turn it around clockwise, it came directly. There was a white blind part on the gearshift lever, and I did not try to insert it. it is actually very easy to insert. thank you friends.
08.05.2020 16:11 # 18
djchaos
[QUOTE = Free] peugeot original 206 gear knob 30 tl ... original as well.
even the original rc metal knob is not 150 tl. How did you get it out to be 150? ?? I do not remember when I pull it out.
yeah I just looked but there are 3 models 1. 130 tl of 30 aluminum
< div> & nbsp;
http://www.peugeotmarket.com/206-vıtes-topuzu-tum-modeller,pr-48.html
