GEAR CHANGE WARNING LIGHT AND SPEED FIXED PROBLEM
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Partner tepee
08.05.2020 20:27 # 1
Taner Tosun
HELLO FRIENDS. 2013 I HAVE TEPEE ALLURE MODEL VEHICLE. SPEED FIXING IS WORKING AT SOME TIMES SOME TIME NOT WORKING. I realized that the gear shift warning light does not work either. I THINK ABOUT THE SAME SOURCE IN TWO FAULTS. BECAUSE THE GEAR CHANGE ALERT WORKS WHEN THE LIGHT IS ON, SPEED STABILIZATION. IT DOES NOT FAILURE ON THE COMPUTER. CHANGED THE BRAKE SEAL FOR EVERY POSSIBILITY. PROBLEM NOT SOLVED. IS THERE ANY KNOWLEDGE ABOUT IT?
08.05.2020 20:27 # 2
KILIC
can it be from the crankshaft position sensor?
08.05.2020 20:27 # 3
Taner Tosun
PROBLEM SOLVED. I WENT TO AUTO ELECTRICIST TODAY. CONNECTED TO COMPUTER. THERE IS A CHAPTER IN THE PROGRAM. EXAMPLE: "BRAKE: PRESSED" WHEN THE BRAKE IS PRESSED "BRAKE: EMPTY" WHEN RELEASED ETC. LIKE. Hence, it can be checked whether the operators are working or not. (ACCORDING TO THE SPEED STABILIZER THAT MAY HAVE: 1. THE BRAKE IS PRESSED TO PRESSED 2. THE CLUTCH IS DETECTED PRESSED. .) THE CLUTCH AT THE COMPUTER WAS CONTINUOUSLY PRINTED. REMOVE THE SOCKET AND COMBINED THE TWO END TO THE WIRE. CLUTCH HAS STARTED TO BE DISPLAYED. It was understood that it was malfunctioning in the clutch manager. MANAGER: 50 TL ORIGINAL. IT IS WORKING NOW. I WANTED TO SHARE THAT MAY USE YOU. HAVE A GOOD DAY.
08.05.2020 20:27 # 4
KILIC
[QUOTE = Taner Tosun] PROBLEM SOLVED. I WENT TO AUTO ELECTRICIST TODAY. CONNECTED TO COMPUTER. THERE IS A CHAPTER IN THE PROGRAM. EXAMPLE: "BRAKE: PRESSED" WHEN THE BRAKE IS PRESSED "BRAKE: EMPTY" WHEN RELEASED ETC. LIKE. Hence, it can be checked whether the operators are working or not. (ACCORDING TO THE SPEED STABILIZER THAT MAY HAVE: 1. THE BRAKE IS PRESSED TO PRESSED 2. THE CLUTCH IS DETECTED PRESSED. .) THE CLUTCH AT THE COMPUTER WAS CONTINUOUSLY PRINTED. REMOVE THE SOCKET AND COMBINED THE TWO END TO THE WIRE. CLUTCH HAS STARTED TO BE DISPLAYED. It was understood that it was malfunctioning in the clutch manager. MANAGER: 50 TL ORIGINAL. IT IS WORKING NOW. I WANTED TO SHARE THAT MAY USE YOU. Have a nice day. [/ QUOTE]
Thank you for sharing my solution. Generally, those who found the solution would not be more fit. I am glad that there is a simple solution for you
08.05.2020 20:27 # 5
Thank you very much for sharing my solution. Thanks to you, we have learned a new piece of information. By the way, it is forbidden to write in capital letters due to forum rules.
