gear
08.05.2020 20:08 # 1
nakrescitoz
mrb friends I have 106 cars 1 month I pushed the pad to the lining pad.
08.05.2020 20:08 # 2
First of all, welcome to search, check the gear rope, Hodja.
08.05.2020 20:08 # 3
nakrescitoz
I checked the gear rope, now it is 2 passes, there is no problem with the gear, but now there is another problem. I can change the printing pad 1 month ago because it can cause high levels even
08.05.2020 20:08 # 4
teacher, there may be a problem in printing, even if it is zero, there may be a production error or there is something that the master did not assemble well. The sound from the gearbox is usually caused by the press lining - the bearing. worst case may be the problem in flywheel.
08.05.2020 20:08 # 5
CVT
The same problem happened to me, we changed the clutch rope, the pressure changed to the pad, the flywheel turned to the valve, the valve adjustment was made, the speed and transition of the gears accelerated, the clutch was very relieved.
08.05.2020 20:08 # 6
CVT
At first try to change the carpet rope 100tl
08.05.2020 20:08 # 7
nakrescitoz
MONDAY MASTER TOGETHER THE CAR WILL BE SPECIFIED WHEN I NEED TO REMOVE THE TRANSMISSION FROM THE TRANSMISSION THE CAR HAS BEEN STARTING TO KNOW THE EMERGENCY NOW I UNDERSTAND THE SURVIVAL, I HAVE HAD A SOUND, I DID NOT UNDERSTAND IT, GOT THAT I WOULD UNDERSTAND THE GAME
08.05.2020 20:08 # 8
OguzhanKucuk61
Follow-up teacher. I also have a click when I'm idle. The master passed over, said nothing.
