Gasoline tank gas pump malfunction!
08.05.2020 16:02 # 1
volkan22
Greetings friends, I said I could not find the solution to my 306 malfunction, let me ask you,
when the car bends to the left, it is normal, it ends when you take the right corner, the 1st line falls when the gasoline hand is in half ... I wonder if the pump is pulling my air_? sometimes to the right
When taking the bend, it becomes like a soner and it gets better when it gets flat.
I would be glad if I can give information about the warm that inserts the gasoline tank.
08.05.2020 16:02 # 2
34sea45
If the petrol pump is the same as the 106s, a very simple rod performs this function, when my own car broke down and repaired it was reinserted.
08.05.2020 16:02 # 3
I couldn't solve the problem, I hope friends will help Gülme
08.05.2020 16:02 # 4
i agree with my dincer brother
08.05.2020 16:02 # 5
[QUOTE = ahmetsimiz] I agree with my dincer brother
I bought 0-40 to 90 Gülme
08.05.2020 16:02 # 6
volkan22
friends problem exactly vehicle 306 2.0 16v
Now, I put gasoline 20 liters or something, for example, I turn left, everything is normal.
I THROUGH THE RIGHT OF THE SAGA tool cut from gasoline! Of course, it takes the bend and flows straight to HOP ANIQUE THE VEHICLE GETS GASOLINE ROAD CONTINUE: S
I WANTED TO ME, I WOULD LIKE I WOULD LIKE TO LEFT THE CAR TO THE LEFT, I REMOVED THE RIGHT SIDE I RUN THE VEHICLE ((NATURAL TO THE LEFT SIDE OF THE VEHICLE AND 10; AFTER SECONDS TO THE CAR))
THE PROBLEM IS NOT ABSORBING THE GASOLINE PUMP GAS IN THE GASOLINE TANK BUT THE GAS PUMP IS UPON IN THE TANK: S
08.05.2020 16:02 # 7
volkan22
SO GASOLINE FLOWS TO THE LEFT WHEN TAKING A RIGHT WINDOW THE PIPE OF THE GASOLINE PUMP BECAUSE THE AIR IS BREAKING THE HOSE, WARDIR IS BORDER AT THE MASTER, I TAKE ME BEND ON THE AUTOMATIC ROAD PAT STOP ME:
08.05.2020 16:02 # 8
34sea45
There may be a problem with the socket of the pump. There may be a lack of contact because the tank will not have any problems as soon as it does not receive a shock. The pump socket or the pump itself is defective.
08.05.2020 16:02 # 9
volkan22
benzin TANK PLASTIC BIGGER POSSIBLE GAS PUMP PIPE MAY HAVE UP TO THE UP IN A LIGHT GASOLINE PUMP DOES NOT TAKE GASOLINE FROM THE TANK HERE!
REMOVE THE RIGHT SAG OF THE CAR WITH THE CRUSHING I DIM VIRAQUE DONERMED WATER 10 SECONDS AFTER THE CAR STOPED TO THE GENERAL
SIDE GASOLINE FLOWS TO THE LEFT HERAL, I CANNOT PUMP GAS PUMP FROM HER, WE TAKE AIR: S FIND A TANK TOMORROW INS.
08.05.2020 16:02 # 10
34sea45
it is the best again, but I think there is a problem with the pump, I had the same problems and the pump has gone completely in 4 days.
08.05.2020 16:02 # 11
volkan22
saol brother walla my pump is holding the same breakdown war gas up halfway at the end of the bend ...
I have a problem in this war for 1 year, but as long as the gas tank is not less than half ...
Thank you bro for your help.
08.05.2020 16:02 # 12
When I parked the car on the sidewalk with a gasoline close to the quarter tank, the car does not work. I pushed the car down the sidewalk and run it. Embarrassed
