gasoline smell in the vehicle
08.05.2020 18:35 # 1
zr`lmn
May it be easy for all of you. Since about 20 days, there has been a smell of gasoline in the car. I looked at all the ports, neither any legs nor anything else. Even while traveling with LPG, there is a smell. I mean, I was buying gasoline when I was buying the last fuel 95 I was normally getting 97 octane this time. Could the problem be due to this? On the right side of the car on the right side of the car, there was a sound, and the places holding the steering pump were broken, I took care of it, and now it was muted, maybe it helps the friends who have such problems.
08.05.2020 18:35 # 2
serkomser
Looks like a problem with rich mix or ignition.
08.05.2020 18:35 # 3
zr`lmn
[QUOTE = Eurest]
It looks like a problem with rich mix or ignition. [/ QUOTE]
Comes when using with LPG, only no smell when using gasoline. Is there a gas consumption when using with LPG? Where should I show the ignition system?
08.05.2020 18:35 # 4
serkomser
You smell gasoline Stern Smile You know, LPG comes into play when the engine gets hot.
Ignition system; Spark Plug, Spark Plug Cables, Ignition coil, Battery. (Vehicles with LPG need extra ampoule batteries because the LPG system draws current.
The smell of fuel is always caused by incomplete fuel. Or there is a leak.
It may be of poor quality fuel. So chained.
08.05.2020 18:35 # 5
zr`lmn
When it comes to me, the scent of gasoline comes to me. I'll take a look at it again and see what they will say
08.05.2020 18:35 # 6
serkomser
LPG is already a problem in itself. When I say I will save, the head is very painful.
Good luck with.
08.05.2020 18:35 # 7
zr`lmn
Thank you very much eurest
08.05.2020 18:35 # 8
Mdeniz
I recommend you to look at the gasoline float under the seat. There was such a smell in us.
