gasoline smell coming from the vehicle
08.05.2020 19:57 # 1
ramazan306gti
Friends, the smell of gasoline comes from the vehicle, it is hard to work. In the morning, when the engine is cold, I run the car, I give gas.
08.05.2020 19:57 # 2
First of all, the problem is most likely caused by the gas pump.
08.05.2020 19:57 # 3
ramazan306gti
Gas pump is defective but after heating it starts to civ civilization then he said carbiratorcuye gotrdm inject injector nothing but the smell of gas always comes
08.05.2020 19:57 # 4
If the gasoline pump that is under the rear seat is leaking from the gasket, the odor may be due to it. malfunction does not mean it does not work, but if it does not pump enough gasoline, it can cause such problems. you should have a check, hodja.
08.05.2020 19:57 # 5
mertgokhan
Hi
I use 307, I had the same problem with me, the air conditioner grills opened the air conditioner without opening or opening the car, the smell of gasoline was coming, the industry was the only thing I took to the master in the industry. It is important to note that if the windows are open, it may have an effect on the smoke coming out of the exhaust.
