gasoline smell and leak
08.05.2020 19:09 # 1
talip206
Good evening my friends car 2002 model 206 petrol + lpg. When the vehicle was loaded with a bit of gas, it smelled of gas. I didn't care because it was coming from outside. Today I came to my mind, I lifted the back seat, I removed the black plastic cover, and I looked at it, gasoline was overflowing. I saw that almost as much of a cup of gasoline was overflowing. It can cause trouble, how much it costs. I would be glad if anyone who shares information talip206 2015-03-12 23:13:02
08.05.2020 19:09 # 2
talip206
I wonder if anyone knows
08.05.2020 19:09 # 3
vpro
Hodja, have you gotten tired of it before, there is a gas pump and a float
the previous owner changed the pump, maybe he couldn't squeeze like a master man, he has an apparatus he gets bored with him and he has to be tightened so that the car does not smell
08.05.2020 19:09 # 4
talip206
[QUOTE = vpro] teacher, have you gotten there by the petrol pump and bugger there
I just bought the vehicle. I do not know what the previous owner did. Where is the place to be bored is the black round cover under the seat. That lid came out quite easily. I think there was a gas pump in the pit in it as much as a cup of gas. Normally there shouldn't be gasoline in there.
08.05.2020 19:09 # 5
vpro
There is a white plastic under that black cover. The bugger's head. He needs to be tightened. If he has a 3-legged tool for 10 seconds, you can tighten it in seconds.
08.05.2020 19:09 # 6
talip206
I hope it is something like that. Otherwise, if the buoy has cracks in the pipes, it is necessary to change the gas pump or something. Room original is quite expensive
08.05.2020 19:09 # 7
vpro
There are 2 pipes outside, if the hepi ball is leaking out, there is a problem in the pipes or there is a crack in the samand.
08.05.2020 19:09 # 8
talip206
I think of the silicon case too. But because of the chemical structure of the gasoline, things like glue type don't work. He was having trouble again. But I'm going to look at the silicon case. Hopefully, as you say, it passes by tightening. Otherwise, the little crack will cost a lot.
08.05.2020 19:09 # 9
vpro
What is the last situation?
08.05.2020 19:09 # 10
talip206
Well, I'm off today. Even though the car goes to LPG, it smells of gasoline especially when it is loaded with a bit of gas. Let's see tomorrow the next day. It is not my half tank of gasoline, I guess The needle was falling in the LPG but it was recovering by itself. It doesn't improve anymore
08.05.2020 19:09 # 11
vpro
No joke, teacher, as soon as you look
08.05.2020 19:09 # 12
talip206
I got the problem today. The master changed a plastic and a piece from it. He said that with a screwdriver, the cover was previously opened and they were forced. I did not know if I was happy or sad. I thought that half a tank of gas was wasted, but it didn't go The event was resolved to 60 pounds. only the master float said it is broken, it is not bad in me, I said the gasoline needle is falling in the lpg. As soon as we've been pretty assertive, he said something like that. Anyway, I said I'm out. Let's see if the red light is on for now, the needle will be lifted when you buy gasoline.
