Gasoline Smell
08.05.2020 21:07 # 1
TolgahanErdogan
My friends problem is that I smell incredible gasoline in my car (especially at high speed). I did not see a leak or leak on the tank (or gasoline evaporated until I saw it) after a while, it was extremely uncomfortable. Especially since there is a baby in the car, it is an issue that I need to urgently solve. If you have any information, I would be very glad if you could help! (306 1.6 Giriffe)
08.05.2020 21:07 # 2
My teacher first of all, remove the part of the warehouse and put a friend back, let him observe if a leak, etc. Otherwise, check the engine compartment intake manifold. Gasoline hoses or injectors are leaking there.
08.05.2020 21:07 # 3
TolgahanErdogan
[QUOTE = sonerkyl] My teacher first of all, remove the part of the warehouse and put a friend back, let him observe if a leak, etc. Otherwise, check the engine compartment intake manifold. Gasoline hoses or injectors are leaking there. [/ QUOTE]
Thank you Professor I will definitely try this too.
08.05.2020 21:07 # 4
GokhaN
open the hood, let's see if the actual smell comes from there is there a wet place
08.05.2020 21:07 # 5
TolgahanErdogan
I tried it a lot, the smell is not there. While buying the vehicle (beg your pardon) I did not cheat and check it thoroughly. The gas tank had no cover. I thought it might be from there, but the smell comes only at high speed.
