Gasoline Problem
08.05.2020 20:05 # 1
spade
Hello, I just joined you. I want to share a huge problem for me. I hope you help.
I own 2004 model 1.6 206cc automatic. I bought it about 3 weeks ago. The warehouse is full for 200 TL, but only 280 km! It says it will go 500 km in the user manual.
what is the reason of this?
In my previous vehicle, the 2005 model roland garros was 206cc. he had the same problem.
urgently waiting for your answers / help
08.05.2020 20:05 # 2
First of all, welcome to us. Well, first of all, when was the last gearbox and engine maintenance of the vehicle.
08.05.2020 20:05 # 3
lazerburak
First of all hello engine maintenance and gearbox is very important in this regard. If it is time to start the automatic gearbox, the car can burn a lot.
08.05.2020 20:05 # 4
spade
We're [I'm] glad to be here. 1 week after taking the vehicle, everything was checked and what was changed or repaired.
those made;
disc grinding
front and rear pads
rear bearing
engine oil
oil filter
air and pollen filter
spark plugs
Vee belt
antifreeze
tensioner bearing
wiper
Transmission oil
steering oil
hydraulic and horn
08.05.2020 20:05 # 5
then my teacher gas filter will change. air filter hoses and air filter boiler to check for cracks, leaks etc. Then the vehicle's map sensor values will be checked. Check the latest petrol ejectors. I assume that the vehicle does not have a misfire or traction problem.
08.05.2020 20:05 # 6
spade
While getting into sport mode in the vehicle, snow and sports modes are blinking as if someone had shot.
Do you have any information about the average amount of the problems you mentioned?
08.05.2020 20:05 # 7
spade
it makes this feeling of back shot very rare. sometimes doing it too fast when in D mode or doing it while sudden braking
08.05.2020 20:05 # 8
My teacher is most likely caused by trouble solenoid valves. but first of all you can change and try a brake sensor (25-30 rubles) if it continues, the selodoid valves may need to be replaced. it costs an average of 600-800 TL.
08.05.2020 20:05 # 9
spade
thank you so much sonerkyl. If I change solenoids, I get rid of both the gas problem and this kickback problem, right?
08.05.2020 20:05 # 10
The problem of gasoline is likely to increase due to the condition of the transmission, but it is wrong to say something definite, but there will be a decrease. kickback problem will be eliminated. Of course, you should find a good master.
08.05.2020 20:05 # 11
spade
I saw similar topics in the forum, but nobody stated it as a petrol problem, so I opened a new topic. My primary problem is gas burning. thank you again. good work
08.05.2020 20:05 # 12
spade
I left the car to the active large service on Friday. Let's see how much they will cost and what is the reason? I will share informational information here when I learn
08.05.2020 20:05 # 13
we are waiting for the results hodja.
08.05.2020 20:05 # 14
spade
I spoke to the service yesterday. First of all, they told me to change what was called the throttle. It was called 780 TL + VAT. Then I said I don't do it, leave it, please do other operations, I said. Then they said; "Let's clean it, maybe the problem will be resolved". I will inform the result positive or negative.
08.05.2020 20:05 # 15
I think it will drop at a certain rate when cleaning and adaptation.
08.05.2020 20:05 # 16
spade
I just bought the vehicle. throttle was cleaned. if it gives a malfunction again, i will share
08.05.2020 20:05 # 17
After use, you should not say the fuel condition again, my teacher went up the km.
08.05.2020 20:05 # 18
spade
unfortunately it is still the same. the reason is unknown. said the staff in the service is normal this winter conditions !! but I think there can be no such thing. I will replace petrol filter etc. I didn't have any lpg. I would be glad if you could investigate the reason
08.05.2020 20:05 # 19
Well, my teacher, I think of them. They need to have gasoline injectors checked. Unfortunately, I had to pass LPG because of gasoline prices. I think it has been 35000 km 1.5 years.
08.05.2020 20:05 # 20
talip206
Hodja, your vehicle has automatic gearbox and factory data of 100 liters within 10 km of the city. Factory data is always low compared to normal use. If you live in Istanbul, don't worry too much that I will drop the fuel. If it burns 13 liters per 100 km, 5.19 x 13 = 67.47 TL. It costs 202 lira at 300 km. Gasoline prices are already flying. I think lpg be comfortable. It has been two years of automatic automation. Sorry, there is no problem.
When it comes to knocking (knock) problem, do not change the throat butterfly immediately, cleaning can work. talip206 2017-01-01 22:01:34
Page : / 2
