Gasoline Pointer Continuously Dropped in LPG Vehicle
08.05.2020 21:11 # 1
samizeldestan
Hello friends. I have a new LPG in 407 and I usually use LPG. But the gas gauge is constantly falling, even though I don't use it. How can I fix this?
08.05.2020 21:11 # 2
darkiron
This is a chronic problem. 5- Get 10 TL fuel is going back to its original state. the darkiron 2019-03-13 08:50:59
08.05.2020 21:11 # 3
recepagdas
Oh my teacher, what did you do? 5-10 TL gasoline is not currently 2 liters :) it was years ago. You need to get at least 7 liters of gasoline (+/- 20%) for the needle to move and recalculate. As of now, unfortunately it is about 50 lira. Keep your tank over half a tank. This way, it resets itself from time to time. Not even half a tank, get on it. This is the best method for both your pump and your indicator.
They also connect the resistor with the button to activate when opening the contact between the 2 cables of the warehouse float. I think it had a value of 46-47 ohms. This resistance value indicates that your tank is full. After you think your tank is full, you release the button and the resistance is disabled and when the contact is opened again, the float works again and calculates the tank. It brings it where it should be. They fasten the gas button under the steering wheel to the place somewhere. Even in big autogas services, when this contact is opened, it is sold in modules that show full and then release. You are not dealing with pushing a button or something. It shows a full release on 2-3 contacts.
08.05.2020 21:11 # 4
darkiron
[QUOTE = recepagdas] oh my teacher what did you do 5-10 TL gasoline is not currently 2 liters :) it was years ago. You need to get at least 7 liters of gasoline (+/- 20%) for the needle to move and recalculate. As of now, unfortunately it is about 50 lira. Keep your tank over half a tank. This way, it resets itself from time to time. Not even half a tank, get on it. This is the best method for both your pump and your indicator. [/ QUOTE]
It is true. I already learned from old subjects. :)
08.05.2020 21:11 # 5
samizeldestan
Thank you for your answers. If I am available, let me go to the industry and consult a master, then this button work.
08.05.2020 21:11 # 6
samizeldestan
If I fulle the gas tank, but never use it, will there be no decrease or fly over time?
08.05.2020 21:11 # 7
recepagdas
There is no shortage of stopping, but as a result, when the vehicle starts for the first time, it runs on gasoline and does not switch to LPG until it gets warm. For this reason, of course, there will be a decrease in your gas. After all, even if LPG is high, you are putting gas once in a while. If you say my full house, 20-30 gasoline in the meantime and keep it full, do not spend any money on the module or something. When the tank is already full, it usually resets when parked and running in the morning (but not always), showing the required value. So if you say my fuller brother, he is the best solution :) recepagdas 2019-03-13 12:56:10
08.05.2020 21:11 # 8
samizeldestan
It is best to take little by little and ful, some money will go, but there is a bagel tube, the car does not show the room exactly right, at least we do not stay on the road :)
08.05.2020 21:11 # 9
Karacocuk24
[QUOTE = samizeldestan] It is best to take a little bit and ful, it will go a little money, but there is a bagel tube, the car does not show the room exactly, at least we will not stay on the road. There was a friend who did not work in the forum to go on such adventures 200 pounds of gasoline follow, then 50 50 reinforcements continue :)
