GASOLINE ODOR COMES INSIDE
08.05.2020 18:30 # 1
alperuzuntas
Friends;
2006 model yenikasa, a brand lpg called landirenzo was installed on my 307 vehicle ..
Even when using LPG, when I need to stop, when I press the brake and clutch, a smell of gasoline comes in.
petrol indicators are not correct because of the chronic problem.
When it is going to stop in some way, is gas flowing aceba, anybody know? Unhappy
08.05.2020 18:30 # 2
kuscu38
You should have a petrol pump under the back seat and look at it, if there is an intense smell, it may have burned the engine or caused a problem.
08.05.2020 18:30 # 3
alperuzuntas
thanks bro, let me look at the first job when I go home after work ..
There is no problem when it goes .. when it stops, the first time I press the brake, the smell comes .. interesting thing ..
08.05.2020 18:30 # 4
kuscu38
If you go from where I said, I think it is not normal when you go, the gas pump intersects the pumping and gives the room out, you check it, if not, try to find the place where the smell comes from ...
08.05.2020 18:30 # 5
jack67
In the hoses of the engine part, there are punctures and leaks due to temperature and age burns. I think also check the engine part.
08.05.2020 18:30 # 6
alperuzuntas
thanks guys, let me see you after work tonight ..
