gasoline needle ...
08.05.2020 18:27 # 1
newlook45
Hello, I went into gasoline the other day, I bought gasoline, I had about half a tank, but the needle was showing zero. I bought the amount of gasoline so increased ibre.20-30 TL does not increase in purchases, I would appreciate if you can help on this issue
08.05.2020 18:27 # 2
Alper134
20 pounds of gasoline, 4.5 lt or something or less moves, you may not notice it, I think it is normal Wink
08.05.2020 18:27 # 3
newlook45
[QUOTE = Alper134] 20 pounds of gasoline 4.5 liters or something makes a little move, you may not notice it, I think it is normal Wink [/ QUOTE]
No, it was obvious before, it doesn't move anymore. Do these gas tanks float, do they float?
08.05.2020 18:27 # 4
Mesut48
[QUOTE = newlook45] [QUOTE = Alper134] 20 pounds of gasoline, 4.5 liters or something, it moves a little bit, I think you may not notice it. Wink [/ QUOTE]
Is the car LPG? The buoy reads level when purchasing 7 liters or more.
08.05.2020 18:27 # 5
ErdiCoskun
If it is lpg, even if you use it in lpg, the needle is falling. Although it is not LPG, it does not play 20 TL gasoline needle, it will not play even when I buy a diesel of 25 TL to my diesel vehicle.
08.05.2020 18:27 # 6
newlook45
[QUOTE = Mesut48] [QUOTE = newlook45] [QUOTE = Alper134] 20 pounds of gasoline 4.5 liters or something moves a little bit, I think you may not notice it either. Wink [/ QUOTE]
no, I usually buy 5 liters of gasoline, because I am a student, I can not get more than 20-25 lira.
08.05.2020 18:27 # 7
ahmed206
Every time I take it, the pointer plays. I have not received any gasoline reading errors so far.
I think there is a software update on this issue in services and mine was updated before I got it, I believe it is now
