gasoline is over
08.05.2020 18:33 # 1
meotler
Hello friends yesterday, the press was very crazy, the event came, lgp was on the way out, gasoline ran out and the car stopped and did not work, gasoline was close, I took it by pushing it up there, took the gas, the car worked :( Do you have any information about why there is a bole?
08.05.2020 18:33 # 2
Ender DOGAN
Lpg can also be a problem recently came to my head tube was disabled. I didn't give it up, I went with gasoline.
08.05.2020 18:33 # 3
it writes the answer in the question. Your vehicle consumes gas and gasoline at the same time.
06.10.2020 22:53 # 4
P3U630T
It has been a long time since the subject has been opened, but this has happened to me today. Maybe someone will benefit. Most of the sequential system LPG systems will not start if there is no petrol in the tank. When the gasoline runs out, the vehicle continues to go in the cylinder but does not work again if it stops. In some LPG systems, there is a method of starting directly with LPG in emergency situations. hit it I don't know) I came in about 80km gasoline and ran out of gas on the way, I continued on the tube. I realized the situation when the vehicle did not work where I parked. Luckily, there was a gas station within a 1 minute walk. I bought gas in a 2.5LT coke bottle and added it to the car. It worked instantly.Also an important point; Peugeot vehicles usually show gasoline when working in the tube, but that tank can actually be EMPTY.
