gasoline is drinking lacquer
08.05.2020 15:48 # 1
buruker
Greetings friends. I have 307 1,4 lpg pejo. It burns 350 cents in me, 350 cents in gas.
08.05.2020 15:48 # 2
too many friends ...
08.05.2020 15:48 # 3
[QUOTE = maverick] too many friends ... [/ QUOTE]
With these values, you can make 400 km with 1 warehouse in the city.
08.05.2020 15:48 # 4
buruker
I buy 100tl of gasoline, 180 km does not see. I bought gas, the last 70 TL is over 200km.
08.05.2020 15:48 # 5
buruker
or what is the normal value of 307 1.4.
08.05.2020 15:48 # 6
As I said, the same result according to your account. you make a warehouse 400 km from the city.
I have a cop friend. 307 1.4. He said, "I'll give you 20500 before I get the car." but I didn't buy it because the case is heavy. He said, "What are you doing?"
you cut the value of yourself from there ...
08.05.2020 15:48 # 7
[QUOTE = maverick], as I said, the same result according to your account. you make a warehouse 400 km from the city.
have you tried simple things? spark plug no more than 4, 20 TL.
filters ... if it runs out of the pressure lining, it means throwing 30-40% of the gas on the street. Friends using 307 will help you with this.
08.05.2020 15:48 # 8
sercinho
My brother, that figure, how high are you driving, how do you drive my skin? My revolution is 1.6 million hp last 1 week ago my olctum burns 0,210 kurus.
08.05.2020 15:48 # 9
I have a friend of the same vehicle in my room, I think the room couldn't get some kind of gas, I think this model has a problem with the gas but it burns too much gasoline.
08.05.2020 15:48 # 10
buruker
this is why I am thinking of selling it. This week the filter spark plug muji bakerracam.km took 55 cents of life. 30 cents would have been super ...
08.05.2020 15:48 # 11
MySteryStorM
It is a 1.4 lpg car and it burns more than the body. I think show it to a master
08.05.2020 15:48 # 12
Engin Tepe
Biizm jetta 1.6 fsi does not burn so much, the new one is having this problem, I have the continuation.
08.05.2020 15:48 # 13
buruker
The car was burning gas 35 cents for 1 year. works and burns a lot. Could this be the reason
08.05.2020 15:48 # 14
ALX
Bit wrong with the car, that's for sure. My 2001 burns 55 in the 325th (355,000 km) gasoline, around 13.5 liters of 97 octane. My brother-in-law has Connect, the vehicle was burning a lot. They gave up the industry and went to FORD authorized service, they solved all the problems. Now his fuel is back to normal. What if they put the wrong oil. The car could not pass the exhaust inspection, be it short.
Also, what does the 3000tl transmission cost mean? Did they wear zero? They want a maximum price of 2500TL even for my gearbox.
I think change the master as soon as possible, but it is best to go to the authorized service test, they want 100TL, of course, but they are the most realistic and accurate detection only.
08.05.2020 15:48 # 15
burakdmr
My friend is far too much ... I was burning 28 krş in the gas usually .. Lpd is burning 17 krş .. 19 krş has not passed until now lpg ...
08.05.2020 15:48 # 16
gozem
Factory data 1.4 petrol manual gear (Inner / Out of town 8.7 lt / 5.5 lt
08.05.2020 15:48 # 17
forewer_fb
sister & nbsp; See I opened a topic (2001 306 xr 100 hp fuel consumption) read my comment there I have data before and after maintenance. maintenance is very important.
08.05.2020 15:48 # 18
Haksen016
My friend, your fuel values are very high, I have 1.6 petrol 307 triptonics & nbsp; I use it even when I complain about the fuel, I burn it to a maximum of 400 thousand liras. But avg. 400 thousand pounds, either 1.4 motor light comes to your heavy vehicle (how long have you been using it, you are the first owner, it is important in your answer to the questions it used to burn less than before) or you need to maintenance your vehicle.
08.05.2020 15:48 # 19
buruker
Today I went, I changed the engine oil and filters. The car became a car. The rammed car is flying right now. By the way, I wrote 1.4 wrong 1.6. I am going to change the flywheel to the gearbox on Thursday 307.
08.05.2020 15:48 # 20
[QUOTE = buruker] I went today, I changed the engine oil and filters. The car became a car in the beginning. The rammed car is flying now officially. By the way, I wrote 1.4 wrong 1.6 I will change the flywheel to the gearbox on Thursday 307. I write the fuel data again [/ QUOTE]
Why are you changing the flywheel, what's the problem?
Page : / 2
