gasoline indicator problem
08.05.2020 16:38 # 1
salihata
In friends 307s or French vehicles, does the gas gauge drop according to the rotation of the wheel, or does it fit lpg? I also know that there is gas in my lpg car, and the tank only gives me a warning as fuel level low & nbsp; I also didn't believe fuel level low one day and I continued to use the car. But, unless I am so sure, every time I buy LPG, do I have to throw 50 lira of gas, then what did I understand? Does this gasoline from the LPG car just not work to start it? I am someone who does 500 km per month. If I throw 1 20 TL of gas a month, will it not take me 1 month or any other carec?
08.05.2020 16:38 # 2
___KxL___
The gas gauge is connected to the wheels, so if you go in the gas, the car is perceived as going in the gas, and the gas in the tank is gone. The vehicle runs with gasoline, when the engine reaches a certain temperature, it passes to the gas and during this time, a little gasoline is consumed. No need to get it every time you buy gas. Once a month or after 8-10 tanks of gas, it is enough to get 75-100 TL gasoline. At least, I have not had a problem, thank God. Even if you say I do not want to deal with this, there is a device called PSA Module. I think the price was 100 TL for BRC dealers.
08.05.2020 16:38 # 3
salihata
[QUOTE = ___ KxL___] The gas gauge is connected to the wheels. So if you go in the gas, the car will perceive it as going in the gas and the gas in the tank is gone. When the engine reaches a certain temperature, it passes into the gas when it comes to a certain temperature. Some gas is consumed every time. When you buy gas, you need to buy 75-100 TL gasoline once a month or after 8-10 tank gases. At least, I am doing so, thank god I did not have a problem. I do not want to deal with this, but I think there is a device called PSA Module. I think the price of BRC dealers was 100 TL. [/ QUOTE]
thanks for answering how to calculate how the gas burns in km, for example, I traveled 75 km the other day with 35 pounds of gas, this is 0.46 cents, this has changed a lot more recently, I did not change my big filter from small filter, I threw software up to 35 cents or so, I don't use the vehicle fast, so when I think about 90, I do not know how many thousand filter changes, throwing software constantly, when there is no gasoline, the vehicle does not work and when I say & nbsp;
08.05.2020 16:38 # 4
___KxL___
Do not be afraid that it will not burn so much even in gasoline. or even from the same pump if possible.
08.05.2020 16:38 # 5
kaan__
you can fix the same problem for 5 liras let's say you gave 10-15 to the master 25-30 lira "Wink"
100 lira There is no situation to require. The system is working in the same way ... there is a detailed explanation on the form
http://forum.peugeotturkey.com/forum_posts.asp?TID=13780&title=lpg-de-benzin-ibresi-dmesi --SOr the-cheap-zM Reviews
08.05.2020 16:38 # 6
salihata
[QUOTE = kaan __] you can fix the same problem for 5 liras let's say you gave the master 10-15 25-30 lira "Wink" < br> There is no situation that will require you to give 100 lira. The system is working the same way ... there is a detailed explanation in the form
http://forum.peugeotturkey.com/forum_posts.asp?TID=13780&title=lpg-de- petrol-needle-dmesi-problem-cheap-zm
the system was great, but I don't have the ability to do it, I think & nbsp; "Big & nbsp; I have to master & nbsp;
08.05.2020 16:38 # 7
C@GL@R
Even in the summer, 10 pounds of gasoline will take you. Now there is a situation, if your car is under the quarter tank, the needle drops like if the car is running in gasoline. .
08.05.2020 16:38 # 8
salihata
This is the issue I complain about, why I have a lpg on top of the tank, I have a lpg in my car. 170 pounds, I will go to 170 pounds km & nbsp; if I fill them all with gasoline or 90 lpg, if I fill 80 gasoline is not the same km? am i wrong? I don't understand much, but I am asking because I was wondering.
08.05.2020 16:38 # 9
ByHack
Unfortunately, the 307s do not measure the amount of fuel independent of the movement of the vehicle and do not reset the amount of fuel in fuel changes below 7,5 lt. If you use more than 7.5 liters of fuel or spend more than 7.5 liters in one go (without stopping the engine :), the fuel information will be updated when the ignition is switched on and off. As for the PSA module, this punch will switch off the gas pump after the vehicle has switched to LPG, so that the pump will not work in vain, and your fuel filter will not be wasted where it stops, let's not forget that the fuel filter of the 307s is integrated into the pump and it changes together in case of failure :) finally LPG There is also a decrease in the fuel gauge in most vehicles and even zero cars, some of them show real fuel information on some of the trip computers, most of those who do not have problems update the amount of fuel each time the ignition is switched on and off. While you are getting the best LPG, buy a gas of 50 lira, and since the weather is cold, inline, the engine will spend a lot of gas until it gets hot)
08.05.2020 16:38 # 10
scorpions_64
I have that same problem. Some friends said that they are in vehicles after 2002-2003, but the same problem is in our 2000 model 206 gti vehicle. I buy gasoline, although I go at lpg, the gas needle is falling. I told the lpg master that I had this problem, and I got the answer "it shouldn't be, the gasoline injectors are missing". So I said I have to reset it in my car and I will make a module myself for the event.
08.05.2020 16:38 # 11
[QUOTE = scorpions_64] I have the same problem. Some friends said that they are in vehicles after 2002-2003, but the same problem is in our 2000 model 206 gti vehicle. I buy gasoline, although I go at lpg, the gas needle is falling. I told the lpg master that I had this problem, and I got the answer "it shouldn't be, the gasoline injectors are missing". So I said I have to reset it in my car, and if I can make a module myself, anyway. Reviews
08.05.2020 16:38 # 12
scorpions_64
[QUOTE = koliva] [QUOTE = scorpions_64] I have the same problem. Some friends said that they are in vehicles after 2002-2003, but the same problem is in our 2000 model 206 gti vehicle. I buy gasoline, although I go at lpg, the gas needle is falling. I told the lpg master that I had this problem, and I got the answer "it shouldn't be, the gasoline injectors are missing". So I said I have to reset it in my car, and if I can make a module myself, anyway.
may not know, I respect you anyway. The man's job is not just peugeot, citroen, that. It wears LPG to every brand and model vehicle. If you look at him, I recently learned this situation ... that the only deaf did not hear ...
