Gasoline Indicator problem
08.05.2020 15:53 # 1
divxmaker
Hello friends. my fuel gauge is over 2 miles from zero and it doesn't play at all, even though I get a petrol. There was such a problem while stopping.
It was also a coincidence. I always get 20 lira and sometimes more gas. yesterday evening gasoline remained low and for the first time I bought 15 lira gasoline, the needle did not change, and in the morning I bought 20 lira the same needle again. what do you think might have happened?
I'm waiting for your help, friends.
08.05.2020 15:53 # 2
murat206
Did you get lpg in the vehicle?
08.05.2020 15:53 # 3
divxmaker
no. original. never been stuck before
08.05.2020 15:53 # 4
murat206
This problem is common in scuba vehicles, your problem may be a float, and as far as I know, when you put less than 7 liters, the needle does not play.
08.05.2020 15:53 # 5
divxmaker
The light was off when I normally received 20 lira. I bought 15 liras for the first time yesterday. and in the morning I bought 20 liras again. It has not changed. I wonder if it stems from it. What should I do.
08.05.2020 15:53 # 6
mitto
It gets better when you buy 50 lira. :) I get 20 pounds of gasoline when I get bored to avoid traveling with a lpg and yellow light. In the past, whenever I bought it, the pointer would jump to half a tank level, but after the last hikes, 20 pounds of gasoline does not move the float. I'm getting 30 lira now. The same thing happened to me yesterday. 20 pounds of gasoline did not move my needle ....
08.05.2020 15:53 # 7
float may be stuck sometimes it will improve over time
08.05.2020 15:53 # 8
divxmaker
I will try what you say.
thank you for sharing your experiences.
08.05.2020 15:53 # 9
7 liter problem. If you buy a few petrol, you will not be able to see if you buy less than 7 liters.
08.05.2020 15:53 # 10
forewer_fb
15- 20 liters of 3.5-4 liters of gas, which you call, which means that there will be air gas for a huge tank :) Maybe you have spent more fuel after the light is lit (aggressive use - stop, get - air conditioner etc.) 15 liters is not enough at this time. can.
08.05.2020 15:53 # 11
forewer_fb
In the meantime, don't remind you to keep the light on as much as possible. otherwise, the possibility of the gas pump malfunction increases. When gasoline is low in the tank, the gasoline pump heats up more quickly.
08.05.2020 15:53 # 12
tilbe307
I do not play when I get 20 tl but put 30 tl look what happens :) our vehicles do not have to bleed
08.05.2020 15:53 # 13
StiFLeR
In my car, the gas needle is showing in full (I wish it was real) :) but not, even my gas light is on. :) Just imagine if he says to himself: D
There is a problem with the float, but it has to be done, God bless, do not stay on the road.
08.05.2020 15:53 # 14
I am waiting for the light to come on to calculate what it is burning, what kind of problem can this be?
08.05.2020 15:53 # 15
metin
[QUOTE = koliva] 7 liter problem. If you buy a few petrol, you will not be able to see if you buy less than 7 liters. [/ QUOTE]
Yeah. When you buy less than 7 liters while buying fuel in the 307s, the float does not report the change to the brain of the vehicle, so the needle never plays. According to today's prices, if you take less than 7 liters X 4.33 TL = 30.31 TL, the needle will not play.
08.05.2020 15:53 # 16
metin
[QUOTE = forewer_fb] meanwhile, don't expect the light to come on as much as possible to remind you. otherwise, the possibility of the gas pump malfunction increases. when the gasoline is low in the tank, the gasoline pump heats up more quickly. [/ QUOTE]
definitely a very important point +1
08.05.2020 15:53 # 17
brunette
Hello,
I am an individual of the gas gauge victim. My vehicle, which has not had any problems since 18 months, gave the gas gauge problem last week. I always throw gasoline when the red light was on. It was the first time I threw the gas light before it burned. The indicator has been canceled. I took 20 TL, the needle did not change again, 20 TL, again, there was no change. The friend needed the car. Although there is at least 90 liters of gasoline, red light is burning. In your articles below, you say that 7Lt must be loaded at the top. But until now, when I dropped 20 TL occasionally, I saw a change in the needle until the following week. You say, let's say we throw the horse over 7 liters, will it light when it falls below 7 liters, or does it light when it normally falls below 7 liters?
In the mail written by orewer_fb friend;
I was always expecting light. I threw gasoline without waiting for the first time.
As a result, if I throw 30 TL or more than 7lt at a time, it will be improved.
Thank you for your answer in advance.
08.05.2020 15:53 # 18
metin
yes, you should buy more than 7 liters of gasoline in 1 time. otherwise the pointer will not play.
If we calculate the price of gas today as 4.71
4.71 x 7 = 32.97 TL so if you buy less than 33 TL gasoline in one time, the needle will not play LOL
08.05.2020 15:53 # 19
tlp
20 TL needle does not move
Then you don't get it for 20 TL.
But go get 40 TL in the biker, whatever the wisdom there is movement in the hand
08.05.2020 15:53 # 20
brunette
gasoline will decrease a little more 50 tl atcam ... as i said before, when i throw 20 tl the needle was changing ... how i dont understand how it gets better when ins 50 tl throw ...
Page : / 2
