Gasoline Indicator Problem
08.05.2020 20:59 # 1
dewismail
Hello friends,
I am new among you, I do not know if there are any rules, my car is 2002 petrol model 206, there is a problem in the gas gauge recently but I do not know why. When I use it, it becomes full, it falls when I use it a bit, but after a place, what does it cause?
Thanks
08.05.2020 20:59 # 2
talip206
The float inside the gas tank may be broken or installed. The last and unlikely indicator is distorted.
08.05.2020 20:59 # 3
dewismail
[QUOTE = talip206] The float inside the gas tank may be broken or installed. The last and unlikely indicator is distorted. [/ QUOTE]
Is there a workshop you recommend?
08.05.2020 20:59 # 4
talip206
No unfortunately. Friends in Istanbul can give advice. A good electrician solves your problem.
08.05.2020 20:59 # 5
dewismail
We changed the float, the problem still continues. It used to be higher up, now it comes up.
08.05.2020 20:59 # 6
[QUOTE = dewismail] [QUOTE = talip206] The float inside the gas tank may be damaged or installed. The last and unlikely indicator is distorted. [/ QUOTE]
If the float is intact, you need to fill the hod tank, dismantle the display screen, remove the needle and insert it. A very common situation for 206s as vehicles age.
